razr tire psi ? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 08-05-2009, 09:15 AM Thread Starter
razr tire psi ?
Just got the 22/10/11 razr's for the rear and wondering what everybody is running in them for presure?
iowa fan is offline
post #2 of 6 Old 08-05-2009, 10:15 AM
@ my weight 200 lbs, run @ 6 psi
post #3 of 6 Old 08-05-2009, 04:50 PM
I would say minimum 5 psi or if you like to jump and ride hard surfaces up to 9.5 psi. It can feel like a better ride with them soft but over the rough they will fight against the shocks.
I usually run 8.5 psi on the rear and 11 psi up front. If the pressures are too high it causes rider fatigue!
Simon Walton is offline
post #4 of 6 Old 08-05-2009, 05:29 PM
700xx crazy's Avatar
Well I run 5.5 psi in the rear (razr) and 6 in the fronts (razr2) and I weight 235 lbs seems to get good traction for me.
700XX CRAZY
HMF Ballance slip-on
PCIII w/"BO MAP"
Outerwear Lid Mod (by me)
Trail Tech Riser
Chub Bars
HONDA Bar Pad
RAZR2 Fronts
RAZR Rears
Elephant Ear Hand Guards(LOL)
700xx crazy is offline
post #5 of 6 Old 08-05-2009, 06:12 PM
I second this. Simon knows his stuff...
post #6 of 6 Old 08-07-2009, 10:35 AM Thread Starter
I thought maybe it should be a little higher with bias instead of radials. ITP says to run 8 in the holeshots I have on the front and they are bias, Thanks for the help
iowa fan is offline
