Which tires break loose? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 03-27-2014, 01:50 PM Thread Starter
Still running the stocker's, they are about 1/2 gone, they still hook up so well that even the 11/16ths L8ton Sway wasnt enough to get it to drift on wet grass... Its driving me crazy, only surface it will drift on is gravel and even then it tries to lift the front so 1/2 the time it just pushes forward with the wheels turned. Stock tires wont get it out of my driveway if theres snow, so im going nuts over here lol. my 83 atc200e drifts better. I've even been pondering lawn mower tires for a reduction in traction to give it the ability to drift on surfaces other than gravel lol.
2 x 82 ATC70's
82 ATC200e
84 ATC200X
85 ATC250es
08 trx700xx
96Steamer is offline
post #2 of 6 Old 03-27-2014, 09:12 PM
i drifted with oem and current gbc xcmaster 22-11-10 you just got to learn how to ride it that means put hrs on it only thing mine wont drift on is grippy ground that goes for donuts and drifting, bodyenglish is key to and figure out when you need to lean up toward front to get the front to bight and rearend will break loose easier just takes practice!
post #3 of 6 Old 03-27-2014, 09:54 PM
nacho's Avatar
Quoted: 11 Post(s)
I agree with tbird. I still have stock tires on mine and the L8ton sway bar. I love the stock tires, probably one of the few who does. I ride in snow, sand, loose dirt, hard pack, and mountain trails that are rocky and root covered. I have no problems with traction or sliding. But I do adjust my tire pressure depending on the terrain.
TRX700XX
KFX700
TRX250EX
85 ATC250R
nacho is offline
post #4 of 6 Old 03-28-2014, 09:40 AM
Big Red's Avatar
I run stock tires with 1" Woody`s gold digger carbide snowmobile studs in winter. But have ridden them in the summer, no problem getting it to drift. (stock swaybar and I`m 220# with gear) I`ll tell you what, it don't slide out on wet root`s! When I first installed the diggers I had too much traction on the ice, and had to cut some of the carbides off. (front end push) Next time I`ll just put diggers in the front also.
Big Red is offline
post #5 of 6 Old 03-28-2014, 11:13 AM
Put wider tyres on the rear and drifting will become easier ..
rappey is offline
post #6 of 6 Old 03-28-2014, 12:24 PM
Big Red's Avatar
Swamp Foxes
I just ordered the 24/10/11 Swamp Foxes, I searched but couldn`t find any pics. Does anyone run them, and what do you think of them? They kind of look like the old D/C Spider Trac`s I had on my 88 250r. Should have never sold that! Bought new off showroom floor at age 16. Still kicking my @#% to this day!
Big Red is offline
