need help - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 04-26-2014, 01:59 PM Thread Starter
need help
Back left tire is wobbling and I cant figure out what it is.
2008 Honda TRX 700
Barker Exhaust
K&N Air Filter
Brock is offline
post #2 of 8 Old 04-26-2014, 02:09 PM
Quoted: 5 Post(s)
lug nuts loose next is bearing
Elmer is offline
post #3 of 8 Old 04-26-2014, 05:56 PM
Or bent rim.
post #4 of 8 Old 04-26-2014, 10:56 PM
Quoted: 242 Post(s)
What kinda whoble? As it's spinning, or when you jack quad up and shake tire?
sent using tappetalk!
post #5 of 8 Old 04-27-2014, 01:50 PM Thread Starter
I put it on blocks and let it run and it was wobbling while nothing was touching it.
2008 Honda TRX 700
Barker Exhaust
K&N Air Filter
Brock is offline
post #6 of 8 Old 04-27-2014, 04:42 PM
Quoted: 242 Post(s)
Grab tire top and bottom, and shake it, check for play. Then try holding tire side to side. If no play, most likely a bent rim.
post #7 of 8 Old 04-29-2014, 09:35 PM Thread Starter
Yeah there's nothing wrong when I shake it. Thanks for help
2008 Honda TRX 700
Barker Exhaust
K&N Air Filter
Brock is offline
post #8 of 8 Old 05-07-2014, 11:42 PM
Ba9801's Avatar
The factory wheels are really soft and bend very easy. I bent 3 of my factory wheels the first week I had my 700XX.
Ba9801 is offline
