Sonic Anti Roll - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 09-18-2009, 02:22 PM Thread Starter
Sonic Anti Roll
If i bought the rear anti roll a arm from sonic racing, would it give me the extra width i need to turn like an atv with a swingarm? thats what im looking to do now.
Flex is offline
post #2 of 8 Old 09-18-2009, 02:59 PM
post #3 of 8 Old 09-18-2009, 03:29 PM Thread Starter
So order the front roll bar first. Would that help my turning the most?
Flex is offline
post #4 of 8 Old 09-18-2009, 04:12 PM
post #5 of 8 Old 09-21-2009, 11:42 AM
The anti roll bar does not make anything any wider. It stiffens up the IRS system so that it doesn't roll as badly.
Simon Walton is offline
post #6 of 8 Old 09-21-2009, 04:57 PM
I kinda like the roll of the XX though. Once you get used to it, when you think its about to roll - its actually digging in to plant the power.
post #7 of 8 Old 09-22-2009, 12:11 PM
With the Sonic system you can change the amount of roll to suit different tracks.
post #8 of 8 Old 09-22-2009, 01:03 PM
Sounds like the rear anti-roll bar should be the first of the two you should get (it is also a few hundred dollars cheaper @ $450..... front = $765). Sonic claims that "Just the rear bar will make your steering magnitudes better but the whole system (front and rear) will make it handle like a formula car."
There are also a couple of videos that explain a little about the anti-roll bar on youtube...... type "sonic anti-roll" to see these videos
Atlanta 700xx is offline
