Anybody running the STI 4/110 adapters? - Club700XX - Honda TRX700XX Forum
post #1 of 18 Old 12-03-2014, 09:21 AM Thread Starter
Scallywag's Avatar
Ive seen them mentioned a couple times. It seems to always come back to a width conversation.
Is anyone actually running them? Do they have steel inserts to keep the aluminum from wearing? Does it need them?
Scallywag is offline
post #2 of 18 Old 12-03-2014, 01:40 PM
All the studs are screwed into the aluminium so no steel needed ?
rappey is offline
post #3 of 18 Old 12-03-2014, 01:54 PM Thread Starter
Scallywag's Avatar
Im really struggling with this so I guess I'll just throw it out there and see how it goes.
I need new tires. Im not fond of the 11's so I thought Id get down to a 4/110 to open up my options. I had pretty much decided on the adapters when I cam across a thread where they took the hubs off of an 09 Rancher to get to the 4/110. Then Baxter throws in that he did it with a 450R hub. Each have there own benefits and issues.
Adapters: There issue is width but I dont really have an issue with that.
Rancher hub: Direct fit but needs shimming on outside/ may have some fit issues with 9 inch rims
450R hub: Needs to be machined to fit the bearing, however gives you the best clearance for rims
To me the adapter is the easiest, and probably the cheapest. What if I end up driving four hours to a new place that has a width restriction though...
I dont care for the ITP rims that fit...or the tire options for the 11". I already have a set of 9" 4/110 rims with brand new tires.
post #4 of 18 Old 12-05-2014, 11:35 AM Thread Starter
Scallywag's Avatar
So I bought a pair of used 450R hubs. They give you the best rim selection and keep it the narrower than the adapter. I got them in last night and they look like they are in good shape.
Ive found a machine shop that im going to talk to about the work. I'd like to take them my existing hub as well, I don't however have a socket big enough for the hub nut. As soon as I get this off I will take a couple pics and then send them to the machine shop
post #5 of 18 Old 12-16-2014, 12:17 AM Thread Starter
Scallywag's Avatar
I put the new hubs on this weekend. 9 inch rims with 20x11 tires. I couldnt be more pleased. Its nice having tires that actually hook up well. I guess the only downside for some would be the width at 55". It doesnt affect me however.
Again i would like to thank Baxter for answering the multiple emails, and everyone else for answering my stupid questions
post #6 of 18 Old 12-19-2014, 12:58 AM
IIIBuckIII's Avatar
There cheep and bend easy a friend wheat threw 2 sets finally broke down and bought dwt .190s like I run
Prm Desert II bumper
Alba Pro Elite Nerfbars Silver/Black
Alba Gas Cap Red
DWT .190 with GBC XC-Master 22x7 Front
DWT .190 with GBC X-REX 20X11-10 Rear
EHS Air Lid
EHS Controller
BigGun EVO-R Full Exhaust
UNI Filter
Tusk 30mm Riser Extenders
IIIBuckIII is offline
post #7 of 18 Old 12-19-2014, 06:12 PM
Jmm24's Avatar
What are you planning on doing in the front to even it out? I imagine a 10inch front-rear width difference will almost give it a 3 wheeler feel. The front end should actually be wider than the rear
Jmm24 is offline
post #8 of 18 Old 12-24-2014, 08:47 PM
I've run 9" rears at a beach race. It handled great and did a full season cross country with a 44" front, 49" rear , Just had a "Eureka" moment on why I could get Big Rex to handle at them races and not at the ovals.
post #9 of 18 Old 12-29-2014, 11:58 AM Thread Starter
Scallywag's Avatar
I love the 450R hubs on the rear. However the front does still push quite a bit. I need new front tires, however I do think I need to widen it. I will not use spacers. I havent looked into my options for widening the front yet.
post #10 of 18 Old 12-29-2014, 03:53 PM
Jmm24's Avatar
You could flip the front rims to get about 1.5 inches more on each side. I believe the stock offset is 3.5+2 with the 2 inches being the outside of the rim in stock form. Maybe not ideal but it will help even the width out for now.
Jmm24 is offline
