CRASHED! Need bar help/suggestions? - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 12-03-2014, 10:47 AM Thread Starter
Amerikanzero's Avatar
Quoted: 22 Post(s)
Hey all. So, the inevitable has happened. I have gone and plowed into a tree and bent up my bars, A-Arms, and stem. I got the A-Arms and new Stem ready to go and now I just need to decide on the clamp and bar. I grew up riding an '88 Honda 250R and looking around on the intertubes, I am boggled as to how many bends and styles there are now. It's a bit daunting.
From what I can tell it looks like most of the 1 1/8 bars are taylored for dirtbikes and not ATV's. Not all, but moslty.
I do a lot of tight woods and trails riding, some XC and harescrambles (just for fun), so a bar with good height and clearance is important. My current setup was running the Renthal 7/8 611-01 (XR100 / TTR125) measures at 30.2" wide and 6.1" tall, which for me has good height and is not too wide.
So, my question to the community is: how many of us are using the 1 1/8 bars and what is your experience with them. Do you feel that the 1 1/8 has a significant performance advantage over the 7/8 or is it mostly rider preference and strength.
Just to clarify, I ride a Honda TRX700xx. Up front I am running Laeger +1 A-Arms, and a Houser +1 stem.. Stabilzer.... The closest I am finding in the 1 1/8 are the Raptor bend and maybe the RC High. I would appreciate any and ALL comments and/or suggestions.
Thanks in Advance guys (and gals)!
Where you come from is gone. Where you thought you were going to weren't never there, and where you’re at ain't no good unless you can get away from it!
Amerikanzero is offline
post #2 of 7 Old 12-03-2014, 03:57 PM
I run the raptor bend with the houser. No complaints.
pswag115 is offline
post #3 of 7 Old 12-03-2014, 03:58 PM
Quoted: 252 Post(s)
I got a pair of these, when admin had them for cheap like $30 shipped. I went with them because of strength and lighter weight than oem.
http://www.oemcycle.com/Item/product...Vid77039375u66
M_Quick is online now
post #4 of 7 Old 12-03-2014, 09:08 PM Thread Starter
Quoted: 22 Post(s)
Thanks for the reply, man. Are you using the 1 1/8 bar or 7/8? How do you like the height? It is comfortable with that +1 stem?
post #5 of 7 Old 12-03-2014, 09:10 PM Thread Starter
Quoted: 22 Post(s)
Yeah, that would have been awesome. too bad they are discontinued.
I was looking at the Tag bars as well. My pegs are Tag and are bullet proof.
post #6 of 7 Old 12-04-2014, 11:18 AM
I had the 7/8 raptor on my stock setup. After a snapped stock steering shaft I went houser + 1 1/8 raptor. Im happy with the set up. I stand alot & it works well for that.
pswag115 is offline
post #7 of 7 Old 12-04-2014, 07:45 PM Thread Starter
Quoted: 22 Post(s)
i almost went with the raptor 1 1/8, but after intense scrutiny and hours of agonizing debates with my other self, I decided on the Protaper Contour Pastrana FMX 1 1/8 bend. I actually built a spreadsheet in excel with all of the bar bends and their respective dimensions calculated in both standard and metric. It came down to four (4) bars, all of them protaper 1 1/8: The Raptor bend, the ATV High, and finally Pastrana FMX bend. Apples to apples they were all within a few centimeters. The Pastrana and ATV were almost identical, but the Pastrana width was just a more narrow. The Raptor would have put me at nearly 7" with my +1 stem. I do like a higher bar, but at 5'7" I feel the Pastrana, which will give me about 5 3/4" will suit me well.
Who knows, I may get crazy and order a raptor bar, throw it up there and just hand tighten the bolts to see how it feels.
Now i am stuck with yet another conundrum.. which grips!?
