Need new front brake pads and rotor - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 10-26-2009, 04:16 PM Thread Starter
De700's Avatar
I was wondering if any one knows of a better quality front brake pads and rotors for the XX? I need to replace mine and not sure if I should go after market or OEM?
Thanks in advance,
CJ
De700 is offline
post #2 of 6 Old 10-26-2009, 04:38 PM
The front pads and front rotors are the same as the 450r. I use Honda pads and Antrax wavy rotors.These rotors worked out at £30 each. I do not know if availible in the US. They maybe under another name , not sure. Hope this helps.
post #3 of 6 Old 10-26-2009, 06:36 PM Thread Starter
De700's Avatar
Thanks for the info. I actually went with some EBC MXS Brake Pad - Sintered Metal and Galfer Wave Brake Rotor. Was told those are two good brands. Hopefully these will last
De700 is offline
post #4 of 6 Old 10-26-2009, 10:44 PM
My fronts went out 2x as fast as my rear. I was lucky I caught mine when I did.
post #5 of 6 Old 10-26-2009, 11:09 PM Thread Starter
De700's Avatar
Well that makes sense because you brake more with your front than you do with your rear. I hardly ever use my rear. The only time I really use it is if I am stuck going up hill and need to get going again, I hold the rear brake as I start accelerating or when I am trying to avoid a big issue.
De700 is offline
post #6 of 6 Old 10-27-2009, 02:04 AM
I heard mine squeaking - probably go with galfers and EBC or Factory pads
