Handlebar questions - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 10-29-2009, 08:42 PM Thread Starter
De700's Avatar
Handlebar questions
So I have a trailtech riser with indicator lights on the plastic shroud. I have tried some Pro Taper Raptor bends and was to high. The brake lines and electrical lines were way to tight when it was turned all the way. I now have a set of trail tech mid bends and its way to short. Trail tech is sending me a set of high bends for free but they are less then a inch higher. Does anyone have any idea's?
Thanks in advance,
CJ
De700 is offline
post #2 of 11 Old 10-29-2009, 10:17 PM
Are you able to reroute your cables and hoses? how much rise do the TT risers have?
2006 Raptor 700
post #3 of 11 Old 10-29-2009, 11:36 PM
Chrisj's Avatar
Thanks in advance,
CJ
I have the TrailTech ATV Mid Bend and it's pretty close to stock. For winter I run the TUSK Chub in the CR bend.
Chrisj is offline
post #4 of 11 Old 10-30-2009, 03:37 AM
BiFfMaN's Avatar
Yah you have to reroute the cables if your changing to a higher then stock setup. I had to when I did the trail tech risers and flex bars.
BiFfMaN is offline
post #5 of 11 Old 10-30-2009, 07:51 AM Thread Starter
De700's Avatar
Well how are you rerouting them? There is only so many places you can reroute them? I took them out of the retaining clips that were built onto the frame, but that didn't seem to help. The TT riser raises it pretty high. The TT mid bend seems to be kind of shorter. I actually compared it to a set of stock ones last week and you can see a big difference.
De700 is offline
post #6 of 11 Old 10-30-2009, 07:52 AM Thread Starter
De700's Avatar
I ca't seem to fnd any measurements on the Tusk CHubb bars. Any idea's?
De700 is offline
post #7 of 11 Old 10-31-2009, 05:15 PM
BiFfMaN's Avatar
Should be a zip tie down below the clips. Those should free up some more slack. Also once your done check your steering full left to right. Your throttle cable and brake line need to be secured also
BiFfMaN is offline
post #8 of 11 Old 10-31-2009, 06:25 PM Thread Starter
De700's Avatar
I believe I did undo that zip tie, but when I put my new plastics on Iw ill double check that
De700 is offline
post #9 of 11 Old 11-01-2009, 04:02 AM
BiFfMaN's Avatar
well if you zoom in on the pic, the right side i routed the line behind the brake line. the other side had plenty of slack. But yah you can see how high my setup is. Im a tall rider, and riding position is very important IMO.
BiFfMaN is offline
post #10 of 11 Old 11-01-2009, 07:17 PM Thread Starter
De700's Avatar
Thats actually interesting. I would be worried that the lines may get snagged on tree branches. I may actually consider rerouting them that way. Thanks
De700 is offline
