spitballing - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 01-16-2015, 11:42 AM Thread Starter
Scallywag's Avatar
spitballing
So Im trying to be creative with a way to get some extra width on my front end. DWT used to make a 10x6 front rim in a 2+4 offset. The down side is that it was a .160. I have found 1 at Rocky Mountain but that is the only one so far, no luck in scaring up a second rim.
I have also found a 10x8 ITP with a 3+5 offset, that is clearly supposed to be a rear rim, the Tusk Voltage tire is made in a 21x7. Would that work? Would the bead be sticking to far out?
Scallywag is offline
post #2 of 11 Old 01-16-2015, 11:43 AM Thread Starter
Scallywag's Avatar
I need new front tires and my rims are mismatched so going this route gets me new tires with matching rims and wider.....
post #3 of 11 Old 01-16-2015, 11:50 AM Thread Starter
Scallywag's Avatar
There was another option there are 10x5 rims with a 4+1 offset. I could turn them around, invert the inside valve stem and machine another valve stem on the outside.
I even called DWT to see if they could pull a set of rims before the valve stem hole was punched. It would be easy enough to machine one on the side I needed it on.... however they were not helpful
post #4 of 11 Old 01-17-2015, 09:20 AM Thread Starter
Scallywag's Avatar
Alright maybe that was too much at once. I think what Im most interested in is buying the 4+1 rims and flipping them.
My question is how vulnerable are the brakes if I go that way
post #5 of 11 Old 01-19-2015, 11:23 AM
Another way to widen using all stock parts yet putting no extra weight on anything is a widening kit (look on ebay?)
Had one on my raptor, gave +3 inches both sides, yet brakes stay inside rims and shock mounts also move out.
The problem with adding width with wheel spacers or rims with a larger offset is it all adds weight to the steering and more pressure on the system.
A widening kit may need longer front brake pipes but a longer tie rod/steering rod comes with the kit.
rappey is offline
post #6 of 11 Old 01-21-2015, 11:58 AM Thread Starter
Scallywag's Avatar
How much stress does it put on the system? I have to get new rims anyway because mine are mismatched. Should I go 2+3? That should give me more brake protection, Ive also decided that I intend to do the sway bar. Should I just get stock offset and let the sway bar fix the push?
post #7 of 11 Old 01-21-2015, 01:12 PM
I wouldnt like to say how much extra stress spacers or rims put on the system, but an anti-swaybar is the best single mod you can make as the results are amazing !
rappey is offline
post #8 of 11 Old 01-21-2015, 04:24 PM
X2
M_Quick is online now
post #9 of 11 Old 01-21-2015, 06:07 PM
Best bet is choose your tyres you want then choose a rim 1" less.
I have a list of rims availible for a 4/144 somewhere that might help but a front 10x5 is availible in a 4:1 offset and a 3:2 offset in a .190 ali. I have a set of 2:3, sadly no longer available.
There's also a 10x6 with 3:3 offset availible. Amazing thing is , you can get a 10x4 , 10x5 , 10x6 , 10x7 and a 10x 8 in a 4/144 bolt pattern.
post #10 of 11 Old 01-29-2015, 11:47 AM Thread Starter
Scallywag's Avatar
I got my new tires and wheels mounted yesterday, so I thought I'd do an update. I decided to go with the DWT .190 rims in a 3+3 offset. That way it gives the brake some coverage and gains a little width. I went with the Tusk Voltage tires.
We are going to ride on Sat, I will give my thoughts afterwards. I still plan on doing the sway bar as well, unless Im impressed with this combo...
