Elka shock question - Club700XX - Honda TRX700XX Forum
post #1 of 17 Old 11-07-2009, 07:09 PM Thread Starter
De700's Avatar
Elka shock question
So since they come set up for your weight, riding style, etc...Can that be re-calibrated if you loose a ton of weight? DOes it ahve to be done by the dealer elka or can you do it with common tools?
De700 is offline
post #2 of 17 Old 11-07-2009, 07:53 PM
trx tas's Avatar
go with the float x evol shock from fox endless adjustment with these shocks i have mine on order
trx tas is offline
post #3 of 17 Old 11-07-2009, 08:14 PM
XCalibur's Avatar
where ca you order these shocks and what would you use for the rear since they are no available for the rear.
XCalibur is offline
post #4 of 17 Old 11-07-2009, 11:29 PM
I have the Elkas and you can re-adjusted. If you do lose allot of weight then I would imagine that you might need to send back but I would ask Elkas since they're the ones who set them up.
post #5 of 17 Old 11-07-2009, 11:31 PM
Elkas has a set for the rear.
http://www.elkasuspension.com/products/honda-atv.html
post #6 of 17 Old 11-08-2009, 09:13 AM
Blak92's Avatar
I dont know about the valving and if that would need to be changed, but the springs are in 50# inc and can be changed on your own, I asked to make sure when I got mine.
Blak92 is offline
post #7 of 17 Old 11-09-2009, 01:07 PM
Both spring rate and valving is affected by rider weight. Springs are easy to change, valving is not so easy. To adjust valving, the shock needs to be disassembled and shim stacks changed, not really something a average person could do. The shocks would not need to be sent back to Elka though for a valving change, any shop that does shock rebuilds/revalves should be able to do the work.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #8 of 17 Old 11-09-2009, 04:40 PM
BiFfMaN's Avatar
Well my question would be how much weight you plan on losing?
BiFfMaN is offline
post #9 of 17 Old 11-09-2009, 08:01 PM
trx tas's Avatar
fox do the podium x for the rear of your bike however i belive these are made to suit you just like the elkas
trx tas is offline
post #10 of 17 Old 11-09-2009, 08:34 PM Thread Starter
De700's Avatar
around 100lbs he he
De700 is offline
