Elka vs. Fox, which are better? - Club700XX - Honda TRX700XX Forum
post #1 of 25 Old 11-22-2009, 04:51 AM Thread Starter
Hello all,
I'm was wondering which suspension I should go with? Elka's or Fox? I know theres different levels of each and was wondering what the word is on each type. My goal is to plushen up the machine and make it a smoother ride and better turner. I currently have Holeshot ICTs on front and rear (I have the 10 inch rear rims), which has helped handling but has sucked up quite a bit of power as the tyres are quite heavy.
riggwelter is offline
post #2 of 25 Old 11-23-2009, 08:08 PM
dagirl71's Avatar
I cant believe no one has answered this post...I was wondering the same thing!
I have been told Elka'a are nice but Fox are better. But that seems to those who own which kind
I did some research and the shocks on the predator fit the 700xx. I have found used stock shocks for them they are Fox Podiums but want the FLOAT X EVOL...but for the $$ if they work why not try them right?
Any thoughts on that?
Hey how abot making this a poll?
Da Girl
dagirl71 is offline
post #3 of 25 Old 11-23-2009, 08:59 PM
They are both reputable companies that make quality parts, Just as you said the owner's of each brand will tell you the same thing.
post #4 of 25 Old 11-23-2009, 09:24 PM
post #5 of 25 Old 11-23-2009, 11:22 PM
trx tas's Avatar
i am going fox i have asked around some shops here in australia and they all say run fox most of them say fox has better quality control and are much lighter with more room to make adjustment especially with the float x evol mine should be here in a few weeks anyway
trx tas is offline
post #6 of 25 Old 11-24-2009, 12:03 AM
Both are a quality shock. If you are looking for different "levels", then you will have to go with Elka, as Fox pretty much just makes the fully adjustable shocks, while Elka you can get no adjustments, compression adjustment only, etc.
I actually have ran both shocks on my 450R's. They both had there strong points and weak points. Currently, my 450R race quad runs Motowoz shocks, and it handles better then my quads did with either Elka or Fox. The second best setup I had was a set of revalved/resprung Elka's, the Fox shocks are next. For a "out of the box" setup, the Fox shox are great, and I think they were slightly better then the out of the box Elka's, but I think any shock, regardless who makes it, will only work its best if it is custom setup for you and your riding style.
If I had to chose between the two, I would probably choose Fox, if the other chocie was the fully adjustable Elka's. (Have to compare apples to apples.) It may even come down to what set I could get a better deal on. I do have to say though, I would chose Motowoz over either one. Once Teixeira Tech finishes up a-arms for my 700XX, I plan on contacting Motowoz to see if they can make a set to fit.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #7 of 25 Old 11-28-2009, 12:57 PM Thread Starter
Thanks for the replies guys. It looks like they are both good. I will check out the motowoz shocks too.
post #8 of 25 Old 11-28-2009, 08:02 PM
I run the Elka Factory Shocks up front and the Elite's out back both pairs have been revalved by Precision Concepts.I have tried Fox,I-shock,Motowoz and Axis.They are all good shocks but my set-up is what works best for me.If your not a full blown racer then any of these companies will be great.Elka makes a wide variety of shocks at different prices.Elka makes a lower grade shock that you can up-grade at any time that way it doesn't hit the pocket book all at once.
Roll Design,Fasst Flexx,Houser,IMS,Maxxis,JFR stem,Pro Armor,BRM,KaN,JFR oil tank protector,Curtis Sparks,Dimler Race Motors
AZDEZRCR is offline
post #9 of 25 Old 06-21-2011, 07:10 AM
Resurecting an old thread...
I recently purchased fox floats and they're on their way. Last week I rode on Elka st. 3 and I definitely liked them over stock. I think there was still room to adjust them to me but it wasn't my xx. I did a search online and there are tons of forums with this question. Almost every forum had guys that ran elkas, fox, motowowz, and a few others. The majority liked fox over the rest. On fox's website you can see a video with the xx and they also have articles from about 4 different magazines on their shocks. Once mine are installed I'll be able to compare them to Valk's and see how they compare side by side.
post #10 of 25 Old 06-21-2011, 02:18 PM
ive been reading up on this alot recently as i was to commit to the 'investment' of better suspension
imo based on what ive read the long and short of it is this. elka is more of a precison made to order outfit with triple rates galore. fox has a wider net for a lower selling price.
elkas major plus, actually thats not true, fox evol major negative is that it doesnt have a spring, so if the bladder blew while riding its gonna be tough and more costly to get back to base.
fox major advantage is that there is no spring (lol) so you can fine tune your own suspension with less need for resprings or revalves.
seems like i am pro fox? actually not i was going to go with elkas! but the sales response and prices that fox has given me as an export order sealed the deal pretty quick.
pity they dont have them ex stock and i have to wait for the next batch.
off topic but for those that have done the ds conversion (or any other like it) did you put the front oe spring on to the back? i like or need (im not sure!) my suspensions pretty soft and the swapped rear spring made the ride better than the ds450 front swap did. try it of you havent. min preload front and max preload rear will result in the quad sitting 1 inch high in the front.
for those that dont want to cut up their bikes (dont blame you) look for a front spring and run all four front springs. this is what i would have done had i known. ride height would be more normal with this setup.
note this will suit lighter riders and/or rougher terrains.
tchui is offline
