Anyone thought of using bead lock screws on the factory rims???? - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 11-22-2009, 08:49 PM Thread Starter
sonic007's Avatar
Just an idea, bad or good?? I used to use bead lock screws back in the day for drag racing/slicks...just drill holes around the rims, seal the holes and lock the beads in place....any thoughts????
Used to keep my 1100hp sbf from ripping the 10" slicks of the rims...
2008 TRX 700xx...FMF Titanium slip on, wrapped head pipe, Pro Taper Fat Bars (motocross bend), 3.5" billet riser, Motion Pro twist throttle, Moose Easy Pull clutch with Shorty 2 finger lever, 13T front sprocket, modified filter cage and air box, anodized hubs, graphite powder coat wheels, trimmed front plastics, tinted headlight, CCP steering stabilizer, Matlock graphics, rear shock revalve, DS 450r front shocks/springs
sonic007 is offline
post #2 of 4 Old 11-23-2009, 02:25 PM
It really wouldn't work like your thinking. The screw through the rim trick was to keep the rim from spinning in the tire under hard launches. You would not ever get enough traction to have this happen on the XX. Second it would not benefit you in anyway like what an actual bead lock is intended for. A beadlock rim is used to lower tire pressure and keep the tire from unseating.
post #3 of 4 Old 11-23-2009, 02:30 PM
i know one of our exmembers sent his stock wheels off omf and had them coverted to beadlocks for $310 for the rears the look hella bad ass.
post #4 of 4 Old 11-23-2009, 09:10 PM Thread Starter
sonic007's Avatar
just a thought...it may help by keeping the beads seated against the rim, even under lower pressures, as well as adding strength in hard turns...trying to pull the beads off the rims....
I think I'm gonna end up going to 10" rims on the rears anyways...
sonic007 is offline
