ASV levers - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 11-27-2009, 10:20 PM Thread Starter
sonic007's Avatar
ASV levers
Looking to buy a pair of ASV levers for the XX...will need a perch for the clutch side...anyone seen one with a switch on?
Where did you buy them from, and what model??
2008 TRX 700xx...FMF Titanium slip on, wrapped head pipe, Pro Taper Fat Bars (motocross bend), 3.5" billet riser, Motion Pro twist throttle, Moose Easy Pull clutch with Shorty 2 finger lever, 13T front sprocket, modified filter cage and air box, anodized hubs, graphite powder coat wheels, trimmed front plastics, tinted headlight, CCP steering stabilizer, Matlock graphics, rear shock revalve, DS 450r front shocks/springs
sonic007 is offline
post #2 of 9 Old 11-27-2009, 10:47 PM
700woodsrider's Avatar
The aftermarket ones don't have a switch, you have to connect the two wires together, and tape them up into the harness. Just remember you will no longer have the starter override.
I got mine from Dennis Kirk.
2008 TRX700XX - Sold
2005 Raptor 660R - Rebuild Project "The Phoenix"
700woodsrider is offline
post #3 of 9 Old 12-01-2009, 03:45 PM
ebay has a ton of then f3 and c5 series
post #4 of 9 Old 12-01-2009, 04:42 PM
tqsatv.com look at the holiday pro pack. Its like $160.
2006 Raptor 700
post #5 of 9 Old 12-02-2009, 11:38 AM
Blak92's Avatar
whats so nice about them?
Blak92 is offline
post #6 of 9 Old 12-02-2009, 04:17 PM
They dont break and you get a little lighter clutch pull and they look trick.
2006 Raptor 700
post #7 of 9 Old 12-14-2009, 04:14 PM
Nasty700xx's Avatar
The ASV C5 's are great, very comfortable and fully adjustable to bring in and out so you can have it closer or farther away depending on how much play you have at the clutch.
Nasty 700xx
Barker performance exhaust
EHS racing fuel programmer
EHS racing air box lid
Hiper beadlocks
Pro taper fat bars
IMS fuel tank
DG full skids
Precision steering dampner
Hinson Clutch
Moose dual gasser throttle
DG fat nerf bars
DG fat pro V front bumper
Powermadd hand guards
ASV C5 brake/clutch levers
Nasty700xx is offline
post #8 of 9 Old 12-17-2009, 10:15 PM
fooleo's Avatar
Got my ASV holiday pack with locking grips!! Just trying to figure out what to do with the parking brake....I mean, we don't use it, do we?! Screw it - its gone!!!
FOOLEO - 260lbs of pure attitude
'08 700xx: 2-Bros Slip-On, Renthal Bars, DG Nerfs, UNI Filter, 13T sprocket, HMF Programmer, 22" RAZRs Front & Back, ASV Levers (Red)
fooleo is offline
post #9 of 9 Old 12-18-2009, 11:26 AM
Nasty700xx's Avatar
Get rid of the useless parking brake. You can take off the rear lever and use a 450 knockout over it.
Nasty 700xx
Hiper beadlocks
Pro taper fat bars
IMS fuel tank
DG full skids
Hinson Clutch
DG fat nerf bars
