HELP!!! Hiper Tech 3 rears.... - Page 2 - Club700XX - Honda TRX700XX Forum
post #11 of 22 Old 04-15-2015, 04:01 PM
Quoted: 255 Post(s)
Have you not contacted the seller and or manufacturer yet?
post #12 of 22 Old 04-15-2015, 08:38 PM Thread Starter
Amerikanzero's Avatar
Quoted: 22 Post(s)
okay w/out further review it looks like 5:2 is factory not 4:3 so the 1" less on inside should clear a-arm. I just got some #'s mixed and still not sure, lol
Dude. It's weird. I am wondering if my a-arms are wonky. I looked at a couple diagrams and it looks like the piece of the upper rm that covers the uppermost part of the knuckle sticks out a bit more than the picture.
Anybody have some pics I could use for comparison?
Where you come from is gone. Where you thought you were going to weren't never there, and where you’re at ain't no good unless you can get away from it!
Amerikanzero is offline
post #13 of 22 Old 04-15-2015, 08:42 PM Thread Starter
Quoted: 22 Post(s)
Also, yes I have contacted both. Neither have had or seen anything like this before which leads me to two conclusions: wonky arm or wrong wheel.
post #14 of 22 Old 05-16-2015, 05:25 PM
I have a set of OMF/DWT 11x7 with re-ring inner and beadlock outside do the same thing. Managed to cure it by putting a washer on the hub before fitting the rim.
Also abit extreme but was thought of was removing some of the metal of the upper a arm or at least reshaping it.
Sorry for not answering youre message sooner. Been busy with the "Rexx's".
post #15 of 22 Old 06-10-2015, 07:23 AM
Mine doing the exact same thing. What did you end up doing? I'm just gonna put a few washers between the wheel & hub.
pswag115 is offline
post #16 of 22 Old 06-10-2015, 09:02 PM
Quoted: 13 Post(s)
rubbing
break out the grinder,, an 1/8" right on the corner ain`t gonna hurt it !!
famous bob is offline
post #17 of 22 Old 06-13-2015, 07:19 PM
bevans143's Avatar
i had the same problem with my OMF's. I talked to the guy I bought them from and the made me a thin round alum spacer at no charge. I thought about the washers too but OMF said it would put uneven stress on the studs and hubs.
bevans143 is offline
post #18 of 22 Old 06-14-2015, 11:06 AM
Are you guys who are having clearance issues running aftermarket rear shocks? If so, that is probably the issue. Most companies fit their products up to a stock quad. Most aftermarket rear shock increase droop, hence the reason for the clearance issue. Options are clearance the wheel, clearance the a-arm, (don't remove to much!) or some type of spacer.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #19 of 22 Old 06-15-2015, 08:11 AM Thread Starter
Quoted: 22 Post(s)
To anyone who may be following this thread, I decided to just grind down that little corner of the upper a-arm like Doug and Bob suggested. I opted to do this as I felt the rear was wide enough and didn't want to go wider by adding spacers or washers. Thanks for all the input guys!
post #20 of 22 Old 06-15-2015, 08:12 AM Thread Starter
Quoted: 22 Post(s)
Oh, and yes, I have Elka stage 3 rears.
