parking brake problems - Club700XX - Honda TRX700XX Forum
post #1 of 30 Old 12-04-2009, 01:11 AM Thread Starter
i need some help, my xx parking brake always needs to be ajusted to work almost every ride. and when ajust i take the rear off the ground to make sure ther not dragin.. i use the front brakes mosly. anybody has this prob to.......
post #2 of 30 Old 12-04-2009, 10:16 AM
De700's Avatar
Maniac,
I would set the adjustment to the loosest position and forget it exsists. The reason is the brake cable and the emergency brake are tied to the same brake caliper. When you adjust the emergency brake there is a piston in the caliper which pushes the brake pad further out, hence when its out further for the emergency brake to work, your rotor rubs against it more and wears your pads down faster. When I had my first ATV I used to do the same thing until I asked why are my pads wearing out so quickly, that was the reason. Good Luck
De700 is offline
post #3 of 30 Old 12-04-2009, 12:45 PM Thread Starter
k thanks.
post #4 of 30 Old 12-04-2009, 06:03 PM
squeak14's Avatar
Quoted: 6 Post(s)
Send a message via AIM to squeak14
I couldn't agree more with De700. That brake is absolutely useless!!! The more you adjust it the quicker you will need to replace your brake pads!! I'm disappointed that after all these years Honda still hasn't improved that problem. My 2002 300ex had the same issue!!
squeak14 is offline
post #5 of 30 Old 12-04-2009, 06:13 PM
De700's Avatar
Yes I am very surprised. Ow Well but I actually found I have no use for the emergency brake actually
De700 is offline
post #6 of 30 Old 12-04-2009, 06:30 PM
The second thing I removed.
De700, What's the small print say under big 3 ?
post #7 of 30 Old 12-04-2009, 07:13 PM
The 1st thing I did to my xx was remove the E brake. Totally worthless...
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #8 of 30 Old 12-04-2009, 07:16 PM
De700's Avatar
Boobs. WHat more motivation do you need.
De700 is offline
post #9 of 30 Old 12-04-2009, 07:44 PM
Lots !
post #10 of 30 Old 12-04-2009, 08:40 PM Thread Starter
de700 dat ur gf lol u must never get bored.
