Question on 10in Rear Rims - Club700XX - Honda TRX700XX Forum
post #1 of 41 Old 12-07-2009, 02:51 AM Thread Starter
De700's Avatar
I have been reading through the threads regarding this and noticed some people have had to shave there A-arm or replace them with racing A-arms, because of the clearance. Is this still the issue? Also if I go with a 10 in rear will the off set be much of a difference to notice on trails and rocky area's ?
Thanks in Advance,
CJ
De700 is offline
post #2 of 41 Old 12-07-2009, 05:23 AM
Where did you read someone had to shave there A-arm or change them to fit 10" rims? With the correct offset you only have to remove the mud scrapers.
post #3 of 41 Old 12-07-2009, 09:40 AM
BiFfMaN's Avatar
I saw it here when doing a search (OMG) for Hipers
https://www.club700xx.com/vb/showthre...ighlight=hiper
BiFfMaN is offline
post #4 of 41 Old 12-07-2009, 10:43 AM
LOL, Is that desert guy serious! Trim an A-Arm to make a 10" rim with an obvious incorrect offset fit? No way would I consider it and I highly doubt OMF would suggest doing so either.
post #5 of 41 Old 12-07-2009, 03:30 PM
BiFfMaN's Avatar
Well shortly after he trimmed he got sonic rear a-arms. Read that in a later post also.
If you go to OMF's web site it has the 11 inch there on the front page.
BiFfMaN is offline
post #6 of 41 Old 12-07-2009, 04:04 PM Thread Starter
De700's Avatar
Yes He has the blue bike if I remember correctly. It made me weary of moving over to a 10 inch rear. ANy idea on does it handle any differently?
De700 is offline
post #7 of 41 Old 12-07-2009, 04:14 PM
Going with a smaller diameter wheel will not make a notable difference in handling. If you change the offset and width's it will.
post #8 of 41 Old 12-07-2009, 04:31 PM Thread Starter
De700's Avatar
do they make the same offset and width as the stock 11 inch in a 10 inch
De700 is offline
post #9 of 41 Old 12-07-2009, 04:33 PM
Not that I know of, But you can have them made.
post #10 of 41 Old 12-07-2009, 05:26 PM
BiFfMaN's Avatar
A staggered set-up that has the rear wider then the front will most likely cause alot of understeer and more tipping on our quad.
IIRC Desert also got wider in the front too so that the outside edge of front and rear were the same.
BiFfMaN is offline
