Cable Length when Raising Handlebars? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 12-11-2009, 02:14 PM Thread Starter
headscratch Cable Length when Raising Handlebars?
Are all of the stock cables on the 700XX long enough to use a 2” riser and aftermarket handlebars? If not, which cables would have to be replaced, and what aftermarket company do you recommend I go with?
Thank You for your hlep!
hellishot is offline
post #2 of 6 Old 12-11-2009, 03:06 PM
BiFfMaN's Avatar
I
did a 1 inch riser and Flexx Quad racer Hi bars...its stretches the wires more then Brake and Throttle lines. You would have to fine alot of slack by cutting zip ties farther down the frame.
BiFfMaN is offline
post #3 of 6 Old 12-11-2009, 03:58 PM Thread Starter
Let’s say I want to keep the wires where they are along the frame, what are my other options for making this work? Do I splice and extend them, or is there a kind of extension kit? I wonder how Matlock did it on his 700XX?
Thank you!
post #4 of 6 Old 12-11-2009, 04:35 PM
I'm using the TrailTech riser with Tusk Fat bar and the cables were long enough. Sad part is that with the Trail Tech Riser, you have to remove the plastic cover so your cables are visible.
post #5 of 6 Old 12-12-2009, 07:33 PM
De700's Avatar
I am using the TrailTech riser as well and the pro taper contour highbend and raptor bend were to high when you turned the wheel the cables were to tights. I am selling a set of x-bars, I have high and mid bend for them. The high bend is brand new never used and the mid bend has been used for 4 months bye me and works fine.
De700 is offline
post #6 of 6 Old 12-12-2009, 09:56 PM
hellishot look at what 5WOP3 did to relocate his light pod in the "how to" steering stem replacement will save you from splicing some wires
500Rubie is offline
