Rear wheel leaning . Help ! - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 06-28-2015, 08:24 PM Thread Starter
roost's Avatar
Hi guys I've rolled my quad a few times and bent a few wheels like a few others I'm sure. My problem is now my rear left wheel has a distinct inward lean . I know the wheel is not bent because it's new and doesn't wobble. The hub seems to turn true also. I took the wheel off to look at the A arms and cast aluminum thing and they all "look straight " to me . I've obviously tweeked or bent something but it's so subtle that I don't know what new parts I need to fix it . My tires are wearing more on the inside so I know it's not just how IRS sits funny sometimes. Has anyone had this happen or is there a component that bends more often than others back there ?
Any experience from the group here would be appreciated thanks.
roost is offline
post #2 of 11 Old 06-30-2015, 07:23 PM
Amerikanzero's Avatar
Quoted: 22 Post(s)
Hmmmmm... You rolled it a few times you say? If you have checked all the usual suspects it may be time to take it the local Honda stealership for a checkup.
Wish I could offer better advice, but depending on how many times it's been rolled, you could be looking at a number of things.
Amerikanzero is offline
post #3 of 11 Old 06-30-2015, 09:05 PM
Quoted: 242 Post(s)
Yeah what he said, if A-Arms are straight, it has to be a bearing. Have you jacked it up and shook it down, to check for play? You said your tires are wearing, so this is on both sides?
post #4 of 11 Old 07-03-2015, 12:37 AM Thread Starter
roost's Avatar
Only the left rear tire is wearing uneaven on the inside. I jacked it up and took wheels off and felt for play and everything feels nice and tight. It hasn't been rolled end over end multiple times or anything but I have gone over backwards and flopped her on her side a few different times .
It handles fine and it's not that badly bent. I was just wondering if anyone else has bent stuff back there and what the weakest bend points may be.
roost is offline
post #5 of 11 Old 07-03-2015, 04:59 PM
Quoted: 22 Post(s)
Most of the rear end "stuff" is pretty solid. Are you absolutely positive it's not the wheel?
Have you taken a close look at the hub?
post #6 of 11 Old 07-04-2015, 02:11 AM Thread Starter
roost's Avatar
I know the hub and wheel are true because when I turn the wheels up on blocks nothing wobbles and the wheel stays on that slight angle. i took the upper a arm off and all the bolts came out nicely and every thing seems to fit nicely no pressure anywhere to re assemble of anything weird . I guess ill just ride her nobody's perfect .
EFM auto clutch, texterratech upper a arms, motion pro twist ,pro taper bars & 3/4 " homemade sway bar.
roost is offline
post #7 of 11 Old 07-08-2015, 11:34 AM
Where the A arm connects to the frame may be pushed in a little and that would make the wheel lean inward
Grizzly_Customs is offline
post #8 of 11 Old 07-17-2015, 04:28 PM
or where it connects to the knucle it bends upward and tire wears inside
e reyes is offline
post #9 of 11 Old 07-18-2015, 09:06 AM
Quoted: 33 Post(s)
I'll 2nd that I believe that it is the end of the upper a-arm. My right side tire has a little lean. Has since I rolled the quad a few months after I got it.
I have actually been thinking about having the upper a-arm and upper knuckle redone for more strength and wheel clearance. I was thinking that the center area of the upper knuckle could be removed and then a rod put on the end of the rear a-arm that would mount to the center of the knuckle. Rath Racing is about 15 miles from my house and they would be my contact if I would decide to make this change.
I egged a 10" rear wheel after jumping and it rubbed the upper a-arms in 2 spots. I have since bought Hiper rims. They won't dent or ding but they can crack under a hard impact. But at least with the modular design I can replace 1 piece of the wheel instead of the whole darn thing.
Luecker is offline
post #10 of 11 Old 07-18-2015, 09:38 AM Thread Starter
roost's Avatar
Glad to hear I'm not not the only one to of bent stuff back there. Sounds like it's most likely knuckle or upper A-arm / mount related . Luecker if you ever change how your knuckle mounts make sure you show us .
roost is offline
