Advantage of a 10" rear wheel???? - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 12-27-2009, 06:21 PM Thread Starter
I just bought my 700xxand was looking into some mods. Other than running the 10" tire sizes are there any real advantages/disadvantages to running the smaller wheel vs. the 11" for trail riding? Just wanna make sure before I buy tires this week.
rolltide05 is offline
post #2 of 10 Old 12-27-2009, 07:09 PM
post #3 of 10 Old 12-27-2009, 07:22 PM
Because of the offset you can run much wider tires on the 11" vs the 10" without having to worry about slamming your rear tires off of trees bc of narrow trails.. I run wide mud tires on the 11's and am going to run rzr's on the 10's.
2008 Honda TRX700XX
22x7x10 Rzr 2 fronts
25x12.50x11 Kenda Bear Claws (buy these now!)
ITP Wheels all around
PRM Rear grab bar
PRM Full Board nerfs
PRM Front bumper that's still off the machine waiting to get re welded
partyboy424 is offline
post #4 of 10 Old 12-27-2009, 08:03 PM
VOO-DOO's Avatar
The only reason I bought the 10's for mine is for sand tires. I am planning on running Bear Claws on my stock 11's.
2008 Black/Charcoal 700xx
Mods:
FMF Stainless Powerbomb header
FMF Titanium Muffler
FMF Programmer
Uni- air filter
10" ITP aluminum wheels with 22" Sand Stars
JT 13T sprocket, with Billet Specialties case saver
and I have a bottle of NOS if needed!
2009 Honda Foreman ES 4x4
Full chasis skid plate, Warn 2500 winch (field tested and approved!), 14" SS wheels wrapped in 26" Baja tires.
I don't have to be the fastest to have fun!
VOO-DOO is offline
post #5 of 10 Old 12-27-2009, 09:20 PM
Same here...that and the fact that no one makes 11" paddles...yet.
post #6 of 10 Old 12-28-2009, 12:02 AM
yeah tire selection is the major advantage especially for sand tires otherwise u have to go to 12's. one disavantage and this happened on my buddys outlaw 525 irs with out the scrapers u can get a rock jamed in there and punch a hole in the rim or tear cv boots up
post #7 of 10 Old 12-29-2009, 05:44 AM
I bought mine because Maxxis do not import there 11" Razr and any other 11" tyre would 23" tall . Too tall for tree dodging. I run Kenda Klaw 20x11x10 which is too wide for the rim. I wish they would build a 20x9.5x10 and ITP would build a beadlock or reinforcing rim on the outside. Maybe send my next pair to OMF and get some fitted.
post #8 of 10 Old 12-29-2009, 10:30 AM
I would have to agree that there is no real advantage to a 10" rear rim except for more tire choices and for sand tires in particular. The offset you'd need to have would also make the rear wider and if you didn't also widen the front as well in some manner, you'd also increase the front end push. IMO
post #9 of 10 Old 12-29-2009, 10:55 AM
XZZzzzzactly.
post #10 of 10 Old 12-29-2009, 04:00 PM
Admin's Avatar
More tire/less rim also improves traction a bit (why you'll see MX and XC riders using 8" or 9" wheels opposed to 10"), gives a slightly 'comfier' ride, and protects the rim more if you hit something.
Admin is offline
