dg nerf bars install questions - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 01-01-2010, 10:20 AM Thread Starter
b.courtney_700xx's Avatar
hi everyone i would like to start off by saying that i just stumbled across this site and after reading a little i was very impressed by the vast amount of knowledge u all posses and just knew i had to join... that bein said i would like to congratulate myself i am the pround new father of a 700xx and 400ex ;) the other day i picked up a set of dg nerf bars for the 700 and am less than impressed with the included instructions if anyone out there owns these bars or has any tips 4 the install i would greatly appreciate ur advice thanks again
b.courtney_700xx is offline
post #2 of 10 Old 01-01-2010, 12:13 PM
Nasty700xx's Avatar
I pm'd you.
Nasty 700xx
Barker performance exhaust
EHS racing fuel programmer
EHS racing air box lid
Hiper beadlocks
Pro taper fat bars
IMS fuel tank
DG full skids
Precision steering dampner
Hinson Clutch
Moose dual gasser throttle
DG fat nerf bars
DG fat pro V front bumper
Powermadd hand guards
ASV C5 brake/clutch levers
Nasty700xx is offline
post #3 of 10 Old 01-02-2010, 06:56 PM
mrtheandrew's Avatar
finished the install yet? how was the fitment?
mrtheandrew is offline
post #4 of 10 Old 01-04-2010, 11:43 PM
fooleo's Avatar
I had problems with the DG install as well. The BS front bracket wasn't even close to fitting properly. Had to cut, fit, weld myself. Cut out the bent plate cross member from the tub mounts and added a piece of flat-bar. Worked like a champ. No issues with over 10 months of riding.
FOOLEO - 260lbs of pure attitude
'08 700xx: 2-Bros Slip-On, Renthal Bars, DG Nerfs, UNI Filter, 13T sprocket, HMF Programmer, 22" RAZRs Front & Back, ASV Levers (Red)
fooleo is offline
post #5 of 10 Old 01-14-2010, 02:07 PM
Nasty700xx's Avatar
Looks good but you will have a big problem if you try and add a belly pan.
Nasty 700xx
Hiper beadlocks
Pro taper fat bars
IMS fuel tank
DG full skids
Hinson Clutch
DG fat nerf bars
post #6 of 10 Old 01-25-2010, 03:47 PM Thread Starter
hey guys sorry it took so long to reply back been ridin ;) but i actually ended up gettin em on pretty eaisly and they fit well no cuttin or weldin
post #7 of 10 Old 03-23-2010, 04:49 AM
atleastitsnotaford's Avatar
That front bracket goes over top of the frame. That may be why you had such problems with it.
atleastitsnotaford is offline
post #8 of 10 Old 03-23-2010, 09:13 AM
kelodwro's Avatar
Fooleo, you have the bracket on backwards.... that is why it didnt fit. It is a close fit with the DGs but it is a glove.
'08 700XX
Power:
EHS bullet box (Thanks Eric!)
Full HMF exhaust system
K&N air intake
Handling:
Flex bars 14* 31" Quad racer
Bling:
Honda Racing MX front bumper
IMS fuel tank
Red Silicon radiator hoses
Gripper seat
kelodwro is offline
post #9 of 10 Old 09-03-2013, 07:49 PM
In the middle of this project now. Ripped the proarmours off and am trying to get the dg's on. Immediete issue is i cant get the foot peg bolts in. I dont remember if the bolts i took out of the proarmour pegs are the oem ones or not is another issue. Any info would be great
fraiolib is offline
post #10 of 10 Old 09-03-2013, 09:14 PM
Well nvm. Didnt notice the peg is renovable from the nerfs
fraiolib is offline
