new wheels any suggestions - Page 2 - Club700XX - Honda TRX700XX Forum
post #11 of 18 Old 01-20-2016, 07:10 PM Thread Starter
sparky277480's Avatar
Quoted: 7 Post(s)
Mquick where did u order ur GBC from.
sparky277480 is offline
post #12 of 18 Old 01-22-2016, 06:40 PM
Ebay lol...
post #13 of 18 Old 01-22-2016, 06:47 PM Thread Starter
Quoted: 7 Post(s)
Ebay lol...
Thanks for all ur help. I went to the motorcycle dealer today and the maxxis tires r going to be $425 for all 4 and I won't have to change the wheel maybe next time I need tires I will buy the rims Cuz the stock ones r getting beat up but they will do for now.
post #14 of 18 Old 01-22-2016, 07:31 PM
for $220 on GBC's and then $80. each on a DWT wheel. You'd be $540 for all new wheels and tires, or just add the 2 rears for now, and that would be $380 saving you a few bucks and new shinny wheels, like these babies! But spend the extra few cent and get the correct lug nuts! Not like I did and learned the hard way.
post #15 of 18 Old 01-22-2016, 08:22 PM Thread Starter
Quoted: 7 Post(s)
Whttp://i1143.photobucket.com/albums/n629/m_quick/Clean%204wheel%20photos/DSC_2888_zpscbdec89e.jp
Why did u have to change the lug nuts did u have to change the hub.
post #16 of 18 Old 01-23-2016, 09:42 AM
If you look at the oem wheels, they are sleeved where the wheel studs come through and they have a tapered lug nut. The DWT wheels are not sleeved and require a flange style lug nut. Some people say you can just flip the oem lug nuts. So I tried that, and was unable to remove my wheel from the hub. The lug nuts are cheap, I wish I knew that when I ordered my wheels. I had to remove my hub and then beat it off the wheel. Later I used a stepper drill bit and opened the hole up slightly, and then used a washer and a flange nut. I only took them off to install my old balder 11" tires/wheels to run on a dyno.
https://www.rockymountainatvmc.com/p...e+nuts+10+1.25
post #17 of 18 Old 01-24-2016, 11:36 AM
blakjak619's Avatar
Quoted: 35 Post(s)
Ok guys I've run the gamut when it comes to the TRX700xx and choosing the right tire/wheel setup. I've run the 11" and the 10" setup in some pretty gnarly conditions (no deep mud). The 11" handles a bit tighter and slightly less roll in the turns but the wider 10" gives a little bit more flex in tire pricing. My recommendation would be a set GBC XC-Masters mounted on OMF's.. I've run this setup in Baja for a couple of years without a single wheel/tire issue. We also run our GBC's on Douglas reds too.
For wheels I'd call Bones at OMF he's a really cool dude who happens to know everything about TRX700xx wheel options. I get my GBC's direct from Greenball as a sponsored rider but have heard of people getting them cheaper online just can't remember where.
blakjak619 is offline
post #18 of 18 Old 01-25-2016, 11:13 AM Thread Starter
Quoted: 7 Post(s)
Thanks for all the input I will try to post pictures when it all done
