steel rims - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 01-08-2010, 01:06 PM Thread Starter
headscratch steel rims
the 700xx is the first spots quad that i ever owned and the first quad that had aluminum rims. and i have to say a hate them, there so weak. yeasterday i was going down my feirnds trail to get to hishose and some where along the way i hit a little rock during a slide and it bent my rear left rim i dint even hit it hard.... so now i want to buy steel rims that i can trust in long rocky rides.
can they be used and where can i get some cheap....
post #2 of 8 Old 01-08-2010, 01:14 PM
BiFfMaN's Avatar
Yup Stock does suck.
ITP i saw had a Steel wheel for the front for like 25 bucks
As for the rear... i have not seen a 11 inch rim yet in Steel
There are plenty of Aluminum rims out there that are stronger then the stockers
$tock
BiFfMaN is offline
post #3 of 8 Old 01-08-2010, 02:06 PM Thread Starter
50$ for a set of fronts....not bad. ill look and tell u if i find anything for the back...
post #4 of 8 Old 01-08-2010, 05:10 PM
BiFfMaN's Avatar
That price was from rockymountain ATV...might find it cheaper elsewhere.
Some 10 inch rims fit the rear..with the correct offset. but you would need a new rear tire to fit the wheel.
$tock
BiFfMaN is offline
post #5 of 8 Old 01-10-2010, 07:29 PM Thread Starter
amd with 10'' i can put razar 2 right
post #6 of 8 Old 01-11-2010, 01:02 AM
right!
post #7 of 8 Old 01-11-2010, 11:21 PM Thread Starter
im gona buy them..... just need offset???????? how much wider will it be?
post #8 of 8 Old 01-19-2010, 11:51 PM Thread Starter
what the stock rear offset and bolt patern..
