all around best gear setting? - Club700XX - Honda TRX700XX Forum
post #1 of 45 Old 01-15-2010, 04:11 PM Thread Starter
now i know weve all talked about the 13tvs14t time and time again. but what im wanting to know is what you think is the best all around set up?
13front 37,38,39 ect rear
14front 37,38,39 ect rear.
post #2 of 45 Old 01-15-2010, 04:19 PM
It would depend on :
Rear tyre size .
Type of terrain you ride on.
Engine mods.
I going back to the 14t front , As I am using 20" rear tyres on 10" ITPs.
As a all rounder , I would think 13t front and 37 rear.
post #3 of 45 Old 01-15-2010, 04:23 PM Thread Starter
this is true there are a lot of other things to take into perspective. im not really sure what the stock rear is either.
post #4 of 45 Old 01-15-2010, 04:25 PM
Stock rear is 37 t
post #5 of 45 Old 01-15-2010, 06:02 PM Thread Starter
so is running a 13t and 38t the same as running 14t 37t or are the back gears different ive heard one in the front is equal to two or three in the rear?
post #6 of 45 Old 01-15-2010, 06:26 PM
Someguy's Avatar
Mechanically in my Head I would say yes, but Mathmatically on Paper the ratios dont add up that way. What I am getting is a ratio of 13:35 Roughly is equal to the same ratio of 14:37. Both Numbers when Crunched actually show the Front sprocket rotating 2.64-2.65 times to achieve 1 rotation on the rear. If I am Wrong Please let me know and Help me to see where I went wrong lol.
DWT Red label Wheels
Razer II tires
Fox Float Evol X Front Shocks
Fox Podium X Rears
Pro Armor Nerfs
Trail tech Bar clamps
Flexx Handle bars
Barker Exhaust
EHS Lid
EHS Programmer
Acerbis Uniko Handguards
2011 Can Am Commander 1000X
Someguy is offline
post #7 of 45 Old 01-15-2010, 06:36 PM Thread Starter
that seems to work out when i did it just now so then one tooth down in the front would be like droping two in the rear. i wonder say if running a 13t front and a 38t rear would be a noticible half way point between torque and topend?
post #8 of 45 Old 01-15-2010, 06:39 PM
Someguy's Avatar
Found a Link that Supports my math and Offers an Explanation to it, I recrunched the numbers and a 14:37 would be 2.64:1 and a 13:35 would be approx 2.69:1 Ratio
http://en.wikipedia.org/wiki/Gear_ratio
Razer II tires
Fox Podium X Rears
Pro Armor Nerfs
Flexx Handle bars
Barker Exhaust
EHS Lid
EHS Programmer
Someguy is offline
post #9 of 45 Old 01-15-2010, 06:39 PM
Someguy's Avatar
Seems to me that that would be the Case yes
Razer II tires
Fox Podium X Rears
Pro Armor Nerfs
Flexx Handle bars
Barker Exhaust
EHS Lid
EHS Programmer
Someguy is offline
post #10 of 45 Old 01-15-2010, 06:51 PM Thread Starter
might be worth a try and would be geting a lighter and stronger sprocket is always a plus.
