Tires - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 01-19-2010, 10:21 AM Thread Starter
LOMO700XX's Avatar
Tires
If the stock tire size in front is 21X7X10 why do people put 23 inch tires on the front? Wouldnt this make it more tippy? IM trying to find a tire set up that will work well in mud and handle good in the dry.
2008 TRX 700XX
1987 ATC 200X
LOMO700XX is offline
post #2 of 7 Old 01-19-2010, 10:32 AM
skier207's Avatar
The taller front tires help give the machine less under steer (push). I put them on mine and it makes a big difference at slower speeds when you want the rear end to come around. If it makes it more tippy it is not noticeable. Everyone here seems to like the Razr/Razr2's for the front.
skier207 is offline
post #3 of 7 Old 01-19-2010, 10:39 AM Thread Starter
LOMO700XX's Avatar
oKay ty for clearing that up. am i gonna be missing anything going from radials to bias plys?
2008 TRX 700XX
1987 ATC 200X
post #4 of 7 Old 01-19-2010, 06:32 PM
23 also helps going over boulders and logs but the best part of 23 is that you do not feel every hole/rocks or bumps.
post #5 of 7 Old 01-19-2010, 07:13 PM
Will the 23s rub pro armor nerfs?I think I remember someone sayin that they were rubbing on their nerf bars but can't remember witch ones they had.I'm thinking about the razor2 23s for the front on mine but not sure if they will rub my pro armor nerfs. Is there anyone on here that is running the 23s with pro armor nurfs?
2008 700xx,fmf 4.1 complete with power bomb headed,fmf power programmer,uni filter,modified lid,Pro Armor fat peg nerfs w/heel guard,Pro Armor pro xc front bumper,ac racing six pack rack,moose 13t front sprocket,motominder hour meter,tusk hand guards,itp t-9 pro front rims,razor2s up front & razors on the rear,ccp steering damper,
Ironhorse is offline
post #6 of 7 Old 01-19-2010, 07:49 PM
phucknutz's Avatar
I am and no they do not rub. I have run them with stock a-arms and with long travel Houser's neither rubbed. I have not run the Maxis tires I use ITP Holeshot XTC's but I am planning on trying a set of the Maxis next. I can tell you the ITP's held up to a beating at the Parker 250, 2 bikes and not a single flat. We also rode them very hard the week before in various desert terrain. You will like the way the bike handles with the 23's.
Big Kidz Racing
Sponsors:
EHS Racing
Barker's Performance
Houser Racing
On The Trail TV
West Virginia ATV Tours
Hinsen Clutch Components
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
phucknutz is offline
post #7 of 7 Old 01-19-2010, 08:16 PM
So I'm good to go with the razor2 23s?they won't rub my nerf bars?
