GBC XC Master 22x11x9 Any Clearance Issues - Page 4 - Club700XX - Honda TRX700XX Forum
post #31 of 32 Old 09-01-2017, 08:28 AM
Quoted: 56 Post(s)
I had put on a new set of Kenda's and wanted to run the "recommended" PSI. I think it was the second trip out I got a whole in the sidewall! I plugged it up and just last week tried a tube (plug would leak slowly). Anyway, the point is I run much higher PSI now!
mumbauer is offline
post #32 of 32 Old 09-01-2017, 01:28 PM
Quoted: 235 Post(s)
Honda recommends 5.1lbs. front 6.2lbs. rear. I run pretty close to the Honda recommendations, 5.5 front 6.5 rear. I have herd people running higher pressure to avoid sidewall cuts when running around sharp rocks. I've never cut a tire yet, but my Son did over the 4th of July weekend. He was riding my original blk trx700xx with 3 1/2 yr old tires on it. 12psi seams like it would ride like a brick. The tire is supposed to absorb some of the impact of the terrain, weather it be from jumping or just ruts and bumps. Also lower pressure helps with traction, which it sounds like you all ready know.
M_Quick is online now
