wider wheels - Club700XX - Honda TRX700XX Forum
 1Likes
post #1 of 15 Old 08-06-2016, 03:32 PM Thread Starter
Quoted: 144 Post(s)
wider wheels
I would like to have wider wheels for the rear, 10X9 's I think would be ideal . been searching ,I can find that size wheel but its not made with 144 hole spacing's .
i'm thinking 10X9 3.0 + 6.0 that fit a BOMBARDIER DS650
all I would have to do is drill the holes were I need them . done it before , it works . but what is that 3+6 going to do to me ?
cataway is offline
post #2 of 15 Old 08-06-2016, 10:01 PM
Call for a wide ass tire. I'd say atleast 12" wide.
M_Quick is online now
post #3 of 15 Old 08-07-2016, 07:41 AM Thread Starter
Quoted: 144 Post(s)
would that be a bad thing ? i'm thinking Maxxis Razr Tires 22x11-10 (6 Ply)
cataway is offline
post #4 of 15 Old 08-07-2016, 12:27 PM
Those will fit on a 10x7 wheel. Same size I'm running on both my quads.
post #5 of 15 Old 08-07-2016, 02:44 PM Thread Starter
Quoted: 144 Post(s)
yes I also have a 10X7 wheel with 22x11x10 paddles them .............but that wheel makes them 10'' wide not 11''
Njolliff1189 likes this.
cataway is offline
post #6 of 15 Old 08-07-2016, 02:51 PM Thread Starter
Quoted: 144 Post(s)
there is a 4/143 Douglas .190 Wheel 10X9 3.0 + 6.0 (BOMBARDIER DS650 BAJA)
that should be relatively easy to modify to 144
cataway is offline
post #7 of 15 Old 08-17-2016, 10:29 PM
CosmicG's Avatar
CosmicG is offline
post #8 of 15 Old 08-17-2016, 10:58 PM
Quoted: 33 Post(s)
Be careful with tire sizes. They are not always accurate. Sometimes a 22" tire is only 21" and sometimes they are are little narrower than advertised. I don't think putting the tires on a wider rim will make the tire wider.
Luecker is offline
post #9 of 15 Old 08-18-2016, 04:44 AM Thread Starter
Quoted: 144 Post(s)
I did get the 4/143 Douglas .190 Wheel 10X9 3.0 + 6.0 wheel and was very easy to make it fit to 4/144.
yes it is wide . I mounted paddle tires on these wheels so wider is not a problem ,I even like it way more better
cataway is offline
post #10 of 15 Old 08-18-2016, 08:19 AM
Quoted: 62 Post(s)
So if I'm calculating correctly you're width should now be about 8" wider than stock? Have any pictures with the tires mounted?
mumbauer is offline
