Collar and plates - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 11-06-2016, 12:14 PM Thread Starter
Collar and plates
the collar seams worn , it shakes up n down and its a very annoyin noise , when I brake it kicks hard , maybe 1/8 of thickness missing, anyone has that problem ? page 17-18 in service manual .
found anwsers , you can delete this post ,thank you .
ulfheonar is offline
post #2 of 5 Old 11-07-2016, 09:03 AM
Quoted: 250 Post(s)
Good to hear, I had same issue a year or two ago. I just replaced both of these.
41303-HP6-A00 PLATE, FINAL COLLAR
After further review, I recall I also replaced the collar part #
41363-HP6-A00 COLLAR, RR. FINAL
post #3 of 5 Old 11-15-2016, 10:25 AM
I replaced all the parts and it still slopped about... Now its really bad...
Thinking about another way to clamp it all down.
rappey is offline
post #4 of 5 Old 11-17-2016, 12:56 AM
I glued a piece of rubber 1/8 thick , dont know long it with last , maybe ill have the piece wielded for more thickness next time . or make a piece of steel ...
gm700 is offline
post #5 of 5 Old 11-18-2016, 03:12 PM
Quoted: 250 Post(s)
headscratch
Sounds like at least a couple of you, let this go way to long before fixing and caused wear to the final case assemble. When mine started moving around, I just replaced the collar and the 2 plates, and it didn't move after that.
