shifter question with nerf bars question - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 02-10-2010, 08:37 PM Thread Starter
I have installed pro armor nerf bars and I love them, thing is with boots on it is tough to get under the shifter. I have not tried moving it yet, can it be done? I'm hoping it is an even star so that i can remove lock screw turn up one tooth and re-install. Has anyone tried? I'm just hoping it is not a key way that that shifter only fits onto one line of teeth and I cant raise it at all. any input before I try so I know what to expect? thanks
olcrazy1 is offline
post #2 of 8 Old 02-10-2010, 08:55 PM
its splined. I moved mine up so i can fit my boot under it. No keyway.
Andy07 is offline
post #3 of 8 Old 02-10-2010, 08:56 PM
Pyetime's Avatar
Piece of cake just do exactly what you mentioned and your boot will fit under the shifter just fine.
Pyetime is offline
post #4 of 8 Old 02-10-2010, 09:23 PM
I tried this but had to lift my foot off the peg to down shift.I ended up putting it back like it was and loosened my net a bit
2008 700xx,fmf 4.1 complete with power bomb headed,fmf power programmer,uni filter,modified lid,Pro Armor fat peg nerfs w/heel guard,Pro Armor pro xc front bumper,ac racing six pack rack,moose 13t front sprocket,motominder hour meter,tusk hand guards,itp t-9 pro front rims,razor2s up front & razors on the rear,ccp steering damper,
Ironhorse is offline
post #5 of 8 Old 02-10-2010, 09:50 PM
blkcruzer's Avatar
I have Pro Armour nerfs too and I did the same thing, moved it, didn't like it and then moved it back to original position and loosened the nets a little.
Jason
2008 TRX700XX Black/Red
Mods:
Trail Tech Vapor with Riser
ODI Rogue Grips
Pro Armour FatPeg Nerfs
PRM rear grab bar
PRM .190 full skid plate
Pro Design K&N Intake
EHS Fuel programmer
22" Razr2 fronts
22" Razr rears
DS450 front reservoir shocks
L8ton 11/16 Sway bar
blkcruzer is offline
post #6 of 8 Old 02-11-2010, 06:30 PM
xx-rated's Avatar
Jason
+1 on that method. The nets on my brake side are much tighter than the shifter side. Moving the shifter up a notch made it too high for my taste.
xx-rated is offline
post #7 of 8 Old 02-17-2010, 11:08 AM Thread Starter
thanks guys, I will try it both ways and see what feels best.
olcrazy1 is offline
post #8 of 8 Old 02-17-2010, 11:57 AM
ara
I just loosened the net.
ara is offline
