The problem with a 10" rear rim is that they have to have a different offset to clear the upper a-arm. Makes the back end wider. This will increase the front end push. A 22" front tire will help a bit... 23" will help more, but not enough. IMO. You might try a 11" rim by OMF so that you can keep the same offset... and go to 22-23 on the front tires.
front 194.80 a peice
rear 250 ish a peice
I did all polished scalloped beadlock and inner reinforecing ring
Total after shipping and i did cod was 909.80 a little pricey but i think they will be well worth the money
are the "6 ply" razrs for the 11" stock wheel heavier than razr's for a 10" wheel (they dont mention "6ply" for the 10"ers)? definitley wouldnt want to add any more weight to the rear end.
Related Threads
134.3K posts
31.7K members
Since 2007
