No front fenders - Club700XX - Honda TRX700XX Forum
post #1 of 13 Old 02-23-2010, 06:33 PM Thread Starter
jamie007's Avatar
No front fenders
After my first ride I decided these stock fenders are pretty much useless, they offer virtually no protection from even the smallest of puddles. I like to be able to see my front tires, the ground, and what the suspension is doing.
Wonder what other fenderless peeps are doing with the mount for the fenders? are you cutting it off or removing the mount entirely? I noticed the mount also supports other plastics so I guess you really can't remove it. I hate to cut it, in case I want to put them back on? Is there any reason I shouldn't remove them?
Jamie
2008 700xx - 23" Razr2's, Razrs, Flexx bars, Trail Tech clamp, ODI grips, Quad Tech desert seat, EHS EFI, EHS Lid, Uni filter, 13t
2000 400ex - DMC Double Barrel, FCR Carb
1987 250r (rip)
jamie007 is offline
post #2 of 13 Old 02-23-2010, 06:54 PM
It's called the Baja look. Most cut it off . Theres a few posts about this . Try a search !
post #3 of 13 Old 02-23-2010, 07:04 PM
thats the way most sport bikes fenders are , utility 4 wheelers offer good splash protection
post #4 of 13 Old 02-23-2010, 07:15 PM Thread Starter
jamie007's Avatar
I tried searching without luck, even if I search for baja look nothing comes up. I guess I'm using the wrong keywords. Thanks!
Jamie
1987 250r (rip)
jamie007 is offline
post #5 of 13 Old 02-23-2010, 07:22 PM
phucknutz's Avatar
Yes I cut it off with a grinder, if you ever want it back it is part of a bolt on bracket and can be purchaced from any Honda dealership. You will need to drill 2 holes in the nosing that bolts to the tank and covers the headlight. the 2 holes will be in the front where there is a bolt to hold the fenders, replace it with a nut and bolt to keep the nosing from blowing off. I learned the hard way
Big Kidz Racing
Sponsors:
EHS Racing
Barker's Performance
Houser Racing
On The Trail TV
West Virginia ATV Tours
Hinsen Clutch Components
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
phucknutz is offline
post #6 of 13 Old 02-23-2010, 07:41 PM
having pics of what you are talking about
500Rubie is offline
post #7 of 13 Old 02-23-2010, 07:47 PM
Found this , it may help but there is another one . I will find it .https://www.club700xx.com/vb/showthre...racing+fenders
post #8 of 13 Old 02-23-2010, 08:09 PM
whaoo there bexter there are a few of us that still wear our fenders proudly!
post #9 of 13 Old 02-23-2010, 08:37 PM
Lol, I wear my fenders proudly also
post #10 of 13 Old 02-23-2010, 09:02 PM
I still have my fenders, Trying to help a fellow rider out. You really wanna see the TT and MX front end i am running this year. Bit of a clue "NO CHICKEN WINGS" shaped like a bullet !
