TRX 700xx Sway bar - Club700XX - Honda TRX700XX Forum
post #1 of 50 Old 02-26-2010, 03:43 PM Thread Starter
Kyle8ton's Avatar
TRX 700xx Sway bar
I just purchased the TRX 700XX (08) took it out thinking this is going to be sweet!!! I was impressed with the torque and the plush ride over bumps... Then I tried to turn.... (horrible under steer and no slide :( ) I did what sounds like most of you have done scoured the Internet trying to find a solution. I am struggling with paying $450+ for a simple sway bar. I am currently in the process of designing an OEM type fit sway bar for my bike. If all goes well I could have them made to be sold for around $150.00 ea. If they work well I might have some of you all try them out for free to get some feedback. Thoughts??
Kyle8ton is offline
post #2 of 50 Old 02-26-2010, 04:23 PM
that sounds like a cool idea. however you will be suprised how well it does actuall handle and slide once you learn to ride it. its a whole different felling than straight axels and you just have to lean harder. but an affordable sway bar would be AWESOME!
post #3 of 50 Old 02-26-2010, 08:55 PM
ill try it out
post #4 of 50 Old 02-26-2010, 09:07 PM
Id love to try it out. I'd cover the shipping for it. Let me know how I can help
post #5 of 50 Old 02-26-2010, 09:16 PM
USMC0861's Avatar
If you need people to test....i'll even pay shipping to me ....need a good Ice racing setup anyways
USMC0861 is offline
post #6 of 50 Old 02-26-2010, 09:21 PM
aschuck's Avatar
I’ll gladly test it at the dunes and some trails.
I'm with USMC0861 on the shipping.
aschuck is offline
post #7 of 50 Old 02-26-2010, 11:43 PM
Garrett22's Avatar
i'll try it for you too. i'll also pay shipping
Garrett22 is offline
post #8 of 50 Old 02-27-2010, 07:47 AM
b.courtney_700xx's Avatar
i would b more than happy to pay shipping and test it out as well
2008 trx700xx
dg steel series nerf bars
13t renthal
3D powertip
razrs on her feet
b.courtney_700xx is offline
post #9 of 50 Old 02-27-2010, 08:45 AM
I'd pay shipping as well and test it out. But like Remington said, if you ride it more you will learn how to slide it around. I learned to lean farther and a little more to the front.
post #10 of 50 Old 02-27-2010, 08:56 AM
All what you need is Razr tires to slide the XX. The stock tires have soft sidewalls allowing them to roll and grip when cornering. The Razr have stiff sidewalls and allow the quad to slide.
