Suspension Pre-Loading for the Big Boys? - Club700XX - Honda TRX700XX Forum
post #1 of 21 Old 02-27-2010, 06:14 PM Thread Starter
Hey, I was wondering what other "bigger" guys did on their preload adjustments? I weigh 260 lbs.
I had both of them all the way tight but the front just pushed too much that way. I read about SimplyOrange's suggestions but the back bucks a bit hard in the trails to go all the way tight in the rear. I was going to try 1/2 pre-loaded on both the front and rear next to see how that goes.
Anyone have better luck than I did so far?
post #2 of 21 Old 02-27-2010, 06:44 PM
Just searching this exact subject. Hopefully someone chimes in with some good suspension setup without suggesting shock upgrade.
NineLivez2Go is offline
post #3 of 21 Old 02-27-2010, 07:51 PM
vfm2010's Avatar
I too am a "sleek" 260lbs. and have the preload set at about half way. I find it tolerable but find myself considering getting the rears revalved and resprung and eventually getting better fronts.
88 LT500R QUADZILLA
06 DVX400 (Son's)
06 TRX250EX (Wife's)
vfm2010 is offline
post #4 of 21 Old 03-01-2010, 09:33 AM
Simplyorange's Avatar
im actually going to soften my rear for hill climbing, im going to lose some sliding ability but itll quit bouncing on the rough terrain.
if you are mechannically capable, try going to a higher weight oil, im going to do this soon.
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #5 of 21 Old 03-07-2010, 04:54 PM
jamie007's Avatar
I weigh 240 and I have the preload backed off all the way front and rear. Works fine for now untill I can get some Elkas. It so rough out here, if I turned up the preload even a little bit, it was bone jarring. I don't do much jumping, so having them soft is fine.
Jamie
2008 700xx - 23" Razr2's, Razrs, Flexx bars, Trail Tech clamp, ODI grips, Quad Tech desert seat, EHS EFI, EHS Lid, Uni filter, 13t
2000 400ex - DMC Double Barrel, FCR Carb
1987 250r (rip)
jamie007 is offline
post #6 of 21 Old 03-10-2010, 12:36 AM Thread Starter
I do alittle jumping, but not a ton. I have them both loaded to 1/2 way now so we will see how that works. I am going to The Cliffs on Saturday so I will test this set up and let you guys know.
Side note: It will be my first day with this thing actually in Dirt/Mud instead of snow!!!! I am really excited to see how it really performs!
post #7 of 21 Old 03-10-2010, 06:25 PM
What is the maximum weight recommended from Honda on these bikes? Isnt it like 243 or something? I am 220 and I was kinda suprised to see that in the book
Diesel700xx is offline
post #8 of 21 Old 03-10-2010, 07:32 PM Thread Starter
What are you trying to say?
post #9 of 21 Old 03-10-2010, 08:09 PM
trx tas's Avatar
i think it is 110kg
trx tas is offline
post #10 of 21 Old 03-11-2010, 12:43 AM
OzLinc's Avatar
I would think that the simplest and cheapest way of fixing this issue would be by useing a hevier weight shock oil......wouldn't be too hard and shouldn't be too expensive either. Way cheaper than a revalve.......
I haven't got my shop manual on me but I'm sure they state the stock shock oil weight in there.
OzLinc is offline
