Wheels - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 03-03-2010, 09:12 PM Thread Starter
Wheels
I would like to know if anyone has had any luck with buying wider rear wheels, and if so what did you buy?
rickthe4th is offline
post #2 of 12 Old 03-03-2010, 09:24 PM
I am running ITP 10x7 rear rims which is a little wider than stock and I have ordered a set of OMF/DWT 10x8.
post #3 of 12 Old 03-03-2010, 09:55 PM
post #4 of 12 Old 03-04-2010, 09:40 AM
ive had great luck, rockymountainatv.com is a great place to pick up some sweet rims and tires. you can get 22x11x10's or 20x11x10 tires from maxiss. you can buy a tire wheel combo at just 274$ for the rear. i am running 20x11x10 maxiss i-razr tires on a set of some sweet douglas t-9 rims. i-razr tires are gncc rated and hook up great! the only mod you have to do is remove the mud scrapers on your quad so you can fit the new tires and wheels. its simple to remove them, unblolt them haha. hope this helped you out, just go to rockymountainatv.com and type in the make model and year. and click tire wheel combo. these tires provide better stability and lower your center of gravity. best of luck to you!
(TRAIL BIKE)2008 700xx, black and grey plastics. Full system HMF performance series pipe,black can, red turn down tip. HMF efi optimizer. K&N pro flow air filter kit. 20x11x10 i-razr tires. 13 tooth front sprocket
(DRAG RACE BIKE) 2005 yamaha blaster......way to much to list on the signature of whats done to it. Should be running 6.8-7.2 seconds in 500ft at 78-80mph. Very inconsistant, hard to get it the same everytime, literally impossible.(down right now, gotta scratch money up to fix it)
JDironcrossxx is offline
post #5 of 12 Old 03-04-2010, 09:55 AM
Baxter, any more info on these? I assume it is a Douglas wheel modified by OMF? What offset are they?
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #6 of 12 Old 03-04-2010, 04:40 PM
Doug
It is a Douglas 10x8 (4+4) 144 PCD fitted with OMF Beadlock.
OMF seems the only ones I have found that carry this rim. Originally going to put a beadlock on a set of 10"ITP's.
The DWT/OMF 10" should add 1/2 2 over the ITP.
post #7 of 12 Old 03-04-2010, 07:17 PM
phucknutz's Avatar
we run the Hiper Carbon Fiber beadlocks! great wheel and ITP Holeshot XCT 22-11-10
Big Kidz Racing
Sponsors:
EHS Racing
Barker's Performance
Houser Racing
On The Trail TV
West Virginia ATV Tours
Hinsen Clutch Components
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
phucknutz is offline
post #8 of 12 Old 03-04-2010, 07:29 PM
Brokenbones's Avatar
How width does it make your quad? I want those Hiper wheel madly I'm popping front and rear tire regulary.And yes I'm running 6-7 psi
Brokenbones is offline
post #9 of 12 Old 03-04-2010, 07:34 PM
That seems like too many psi to me. I have bear claws on the stock rims and I run 4 psi rear and 3.5 psi front
post #10 of 12 Old 03-05-2010, 06:49 PM
How long have you ran them on your quad?
