understeer correction test - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 03-04-2010, 08:50 PM Thread Starter
Brokenbones's Avatar
Today I've put back my rear 11'' wheels and kept the wider front Itp 3+2 offset rims with 22-7-10 I had. Also I screwed the front shock a 1/4 inch and the rear shocks a 7/16 inch. So I tried it and made a huge difference for me
So my :
front end is 47.5 inch wide
rear end is 46 inch wide
It looks like this bike like to be wider in the front!
FYI I weight 160lbs.
Brokenbones is offline
post #2 of 12 Old 03-05-2010, 12:03 AM
BiFfMaN's Avatar
I did the same thing and got the same results....also with the houser A-arms turned my bike into a whole different beast.
$tock
BiFfMaN is offline
post #3 of 12 Old 03-05-2010, 12:13 AM
i fliped my front tires around....worked for me
post #4 of 12 Old 03-05-2010, 07:51 AM Thread Starter
Width?
What is your real front and rear width now with your set-up?
I have read an article about solid axle bike and they said that if the rear is narrower it tends to be more prone to slide and this not they want but for an irs bike it change the things positively.
post #5 of 12 Old 03-05-2010, 08:13 AM
Anything to give your front end more turning leverage over the rear will help. Reversing the wheels will help but it will also create more arm fatigue as the wheels will also have more leverage on your handlebars.
post #6 of 12 Old 03-05-2010, 12:11 PM
BiFfMaN's Avatar
my fronts are now 3+2. Yes it makes the bike wider, but with the added camber up front also i was able to go into corners much faster. I can turn good on dunes , Had video..but my friend the camera operator did not operate the camera very good. Plus the 3+2 fronts helped with the 4+3 rear paddles.
Everywhere i ride and all the things i do i felt that front offset was best for me. and so far it is.
Also note that i got the Sonic rear sway too..that too eliminated most of the front push.
Now i have said before on this forum that people need to throw out this thinking quad suspension and think Car. The SRA is a Oversteer generator...yes its fun to whip the back around...but can also be dangerous.
Options like Rear sway bars, Tire offsets, Tires and Spring rates/dampening...now allow you to tune the bike the way you want it.
$tock
BiFfMaN is offline
post #7 of 12 Old 03-05-2010, 04:44 PM Thread Starter
So far this was a quick fix, serious upgrade to come !
post #8 of 12 Old 03-05-2010, 04:50 PM Thread Starter
You're right Scuzz! Reversing the wheels affect the turning reaction.Look at the can-am ds450 how they engineered the front spindles
post #9 of 12 Old 03-05-2010, 05:12 PM
So my :
I am abit confused so bare with me . You are running 3+2 front rims on the front , is that 3" outside offset and 2" inside ?
post #10 of 12 Old 03-05-2010, 05:20 PM Thread Starter
3:2 Offset - This offset is 3 inches inside and 2 inches out side. This is the most common offset and easiest to find.
