New Kid with Left Rear suspension issue - Page 2 - Club700XX - Honda TRX700XX Forum
 2Likes
post #11 of 18 Old 01-10-2017, 07:13 PM
Quoted: 255 Post(s)
Also pivot Works offers a lifetime guarantee on their bearings. I tried the cheaper ones only to have them wear out within a season. I'm also wondering where you're located? Is the main wheel bearing okay? (Light bulb) What about the knuckle bearings? I can't see the inside arm bearing causing wheel rub but idk?
Technoholic likes this.
post #12 of 18 Old 01-10-2017, 09:19 PM Thread Starter
Interesting! Just looked at their WEB site. Their A-arm kit sells for $89.95 but it is not clear if it covers 1 or both pivots. It is certainly worth looking into. Thanks!
To answer your question, I am in the East Phoenix valley area, Queen Creek. From what I see now the wheel bearing seems OK. It will be examined more closely when I tear into things.
Technoholic is offline
post #13 of 18 Old 01-11-2017, 09:27 AM Thread Starter
Here is the problem that caused the wheel to hit the a-arm. Don't know why I didn't see this sooner.
Notice the A-arm hitting the wheel!
post #14 of 18 Old 01-12-2017, 12:21 PM Thread Starter
Parts ordered from Pivot Works. Their price is a bit lower that OEM parts would be and the lifetime warranty made that decision a no brainer.
post #15 of 18 Old 02-05-2017, 12:03 PM Thread Starter
If anyone is following this thread, installing new pivot bearings did not solve the wheel to a-arm interference. Turns out the upper a-arm was bent. Replacing it solved the wheel clearance problem.
Now when the bike is up on the lift, that left wheel looks to hang a bit lower that the right. I have no way to know if that is normal. Can anyone comment?
post #16 of 18 Old 02-05-2017, 12:25 PM
Quoted: 143 Post(s)
Originally Posted by Technoholic View Post
I have been through this thing over and over. Removed the sway bar which turned out to be an 11/16" L8ton, disconnected the shock an pushed, pulled pried every pivot point and bearing on the whole left rear side. I can see nothing worn, loose or bent. The tires are original equipment so the assumption was the wheels are also but maybe not? Both wheels hit the a-arm only on the left side and only when the machine is off the ground. I took and mounted them on the front to spin freely and there was no wobble. They are Honda 11" wheels but there is no part number stamped on them. I cannot find the factory offset specs. Can anybody help with that?
Such is the challenge with buying used equipment. I am the third owner and just brought it home days ago. The left side fenders are pretty scared up so it might have been rolled onto that side. Still I cannot see any evidence of suspension damage. Could I have the wrong wheels?
It most likely is not the wheels. Upon closer inspection, the inside front bearing on that a-arm is shot. If that is not THE problem it certainly is A problem. Now to decide on replacing the a-arm bearings or the whole a-arm assembly. I will post pictures if I get time to set up an external site. Thanks for your input.
if you will check i'l bet all the bearings are dry as a popcorn fart
blakjak619 likes this.
cataway is offline
post #17 of 18 Old 02-05-2017, 05:10 PM
Quoted: 255 Post(s)
X2 especially the lowers, as they usually will see more water & mud.
post #18 of 18 Old 02-05-2017, 10:50 PM Thread Starter
The uppers are new on the left side. I will put cleaning and greasing the rest on my to do list.
