Pro Taper Handlebars - Club700XX - Honda TRX700XX Forum
post #1 of 19 Old 03-10-2010, 12:16 AM Thread Starter
Has anyone tried the Pro Taper SE ATV High Bend handlebars? I was looking at picking up a set and I was wondering if all the cables were long enough to work with them. If you have them please let me know.
post #2 of 19 Old 03-10-2010, 01:03 AM
blkcruzer's Avatar
I have the same bars in the Medium bend and there was plenty of slack in the cable still so you will probably be ok.
2008 TRX700XX Black/Red
Mods:
Trail Tech Vapor with Riser
ODI Rogue Grips
Pro Armour FatPeg Nerfs
PRM rear grab bar
PRM .190 full skid plate
Pro Design K&N Intake
EHS Fuel programmer
22" Razr2 fronts
22" Razr rears
DS450 front reservoir shocks
L8ton 11/16 Sway bar
blkcruzer is offline
post #3 of 19 Old 03-10-2010, 04:50 AM
Do you have anything else? Like risers or anything? i was just wondering b/c I am looking into these as well. How do you like the medium bend? I am 6'2'' so was curious about those. The only new cable I want to get is a throttle cable cuz I am going to twist throttle.
post #4 of 19 Old 03-10-2010, 06:09 AM
phucknutz's Avatar
The pro tapers are great, my bike has been upsidedown 2 times and the bars are perfect. All the cables are fine, I use atv high bend. I would reccomend a dual gasser throttle, terry cable or moose make one and they are great, best of both worlds. You use stock cable with it.
Big Kidz Racing
Sponsors:
EHS Racing
Barker's Performance
Houser Racing
On The Trail TV
West Virginia ATV Tours
Hinsen Clutch Components
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
phucknutz is offline
post #5 of 19 Old 03-10-2010, 08:33 AM
ATV Hi handlebar is actually around .8" lower than stock if you just swap them. The highest ones are the raptor bend which are very similar to the xx stock bend. If you want to go any higher you will have to get risers. If considering risers the most you can go above stock without changing cables is about 1.75", you have to reroute them though. Let me know if you need more info on the risers.
2006 Raptor 700
post #6 of 19 Old 03-10-2010, 10:00 AM
blkcruzer's Avatar
I have the Trail Tech Clamps, which do add some rise over stock, I am only about 5'7" and they are perfect for me, So i would suggest the taller one for ya.
Mods:
ODI Rogue Grips
PRM rear grab bar
EHS Fuel programmer
22" Razr2 fronts
22" Razr rears
post #7 of 19 Old 03-10-2010, 11:24 AM
phucknutz's Avatar
oh yeah and I run a Houser +1 stem, no issues
Big Kidz Racing
Sponsors:
EHS Racing
Houser Racing
On The Trail TV
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
post #8 of 19 Old 03-10-2010, 11:26 AM
phucknutz's Avatar
instead of spending money on the trail tech riser, you should seriously consider the Houser stem, not too much differance in cost and a huge impeovement plus the anti-vibration bar clamp is awsome! www.houser-racing.com
Big Kidz Racing
Sponsors:
EHS Racing
Houser Racing
On The Trail TV
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
post #9 of 19 Old 03-10-2010, 02:34 PM Thread Starter
According to Rocky Mountain ATV
Pro Taper SE ATV Hi is 32" Wide 6.3" High and 3.94" Pull Back
Pro Taper SE Raptor is 30.3" Wide 5.63" High and 3.41" Pull Back
according to the the ATV hi is taller than the raptor by just under .7"
post #10 of 19 Old 03-10-2010, 02:56 PM
You're right if you stay with 7/8" bars ;) If you go to fatbars like the contour then you will be around stock (you need fatbar adapters that raise a bit). The ATV Hi fo the contour bars and the SE bars have different rise! LOL
2006 Raptor 700
