CO2 Cartridge tire pump - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 03-10-2010, 08:34 PM Thread Starter
ara
Anyone here use one of these or similar? I was looking in the rockymountainatvmc site and found this one.
http://www.rockymountainatvmc.com/pr...dFamilyId=5283
With some extra cartridges, it looks like a useful tool to carry on long rides.
Any feedback would be great. Thanks
ara is offline
post #2 of 9 Old 03-10-2010, 08:37 PM
I have personally only gotten one flat tire on a trail ride, all my others have been from racing. I use slime in just about everything, and that cures a lot of puncture stuff. It does seem like an innovative idea though.
post #3 of 9 Old 03-11-2010, 10:17 AM
BiFfMaN's Avatar
i been using this one....
http://www.rockymountainatvmc.com/pr...FamilyId=11236
it has alligator clips so you can use the quads battery to run the pump, and its pretty small
$tock
BiFfMaN is offline
post #4 of 9 Old 03-11-2010, 11:30 AM
After my friend got a puncture in his side wall 10 miles away from nowhere. He had the same type of repair kit with him... he had to use 2 plugs in his side wall, but he was able to ride out. I now carry one of these types of repair kits in my CamelBack on long rides. You can get these type of repair kits at most dealers and all over. In the tread portion of the tire, it is a permanent repair. In a side wall, it is enough to get you back to civilization.
post #5 of 9 Old 03-11-2010, 11:43 AM
I carry a pump like this http://www.amazon.com/Blackburn-Moun.../dp/B000BNZ0L0. [email protected] can leak out then your stuck. The air pump does not take up much room.
lager1 is offline
post #6 of 9 Old 03-11-2010, 12:41 PM
Use this one too. Works great,
2006 Raptor 700
post #7 of 9 Old 03-11-2010, 02:01 PM
I am sorry. I thought you were asking about repair kits and not just a way to inflate a tire. A way to inflate a tire on the trail alone does not take into consideration why you have a flat tire in the first place. If you don't take care of why you have a flat tire, all the air in the world won't help because all you've done give your tire more to leak back out. JMO
post #8 of 9 Old 03-11-2010, 10:56 PM
roadkill, I assume they take plug kits with them, it is just they say they are taking a pump instead of a can of CO2 is all.
post #9 of 9 Old 03-12-2010, 09:54 AM
I assumed that as well. However, I don't like to assume anything as most kits I've seen have some type of plug AND a way to inflate the tire all in one kit.
