Rear suspension - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 03-12-2010, 12:11 PM Thread Starter
Tory trx's Avatar
Rear suspension
I was wondering if anyone with the stock suspension has noticed this.. Looking at the bike from the back, the rear wheels seem to be cockeyed. The top of the rear tires looks to be slanting in towards the frame. Is this normal and if it is will a preload tweak fix the problem??? I just assume that if the tires are leaning in, it might make for uneven wear. Right??
Tory trx is offline
post #2 of 5 Old 03-12-2010, 02:46 PM
700xxx's Avatar
have some one sit on it then look at it. its just the irs the way its desinghed.if you compress it enough it will tip the top of the tires out.
700xxx is offline
post #3 of 5 Old 03-13-2010, 05:46 PM
There's nothing wrong with them. As 700xx said, when you sit on the bike they will level out. This is common on all IRS setups.
post #4 of 5 Old 03-13-2010, 07:05 PM
redrider's Avatar
all IRS setups except for the canam's. thier set up only allows for vertical movement. pertie cool imo
http://www.can-am.brp.com/en-US/technology/
redrider is offline
post #5 of 5 Old 03-14-2010, 10:03 AM Thread Starter
Tory trx's Avatar
Yeah your right. I jumped the gun. I noticed while pressing down on the rear grab bar that the wheels leveled out. Quick fix.
Tory trx is offline
