Rear Tire sidewall puncture repair - Club700XX - Honda TRX700XX Forum
post #1 of 13 Old 03-15-2010, 10:38 AM Thread Starter
force61's Avatar
I had just gotten my 700xx and was about 20 minutes into my first ride and me and my buddies pulled to the top of the hill to check out the view and noticed my right rear tire was nearly flat. It turnes out a rock had punctured about a 3/4 cut into my sidewall. After looking around for tires and not wanting to spend another $200 on a brand new bike for new tires I decided to try and convert it over to a tube. We have 10" tubes at my work that we discard with each tire change so I figured I'de give it a chance even though the tube is slightly smaller then the wheel diameter on my 700XX. At most since the tube was free it would cost me the valve stem I had to cut off. I also had to put a patch on the inside of the tire because when I first broke the bead a ton of sand had been pushed into the tire thru the cut. Anyways the tube stretched over the wheel just fine and after cramming it into the tire cavity I inflated it, then deflated it and finally reinflated it in an attempt to work out any folds that may have been in the tube. After about a 5 hour test run yesterday it held up great and I am extreemly happy with it. Just keep in mind if you do it, when you first inflate the tube you are going to have air trapped in pockets between the tube and the tire so for quite a while there will be air leaking out of the tire which is normal. Even after it sitting for 5 days and 1/2 hour into my ride some more trapped air must have shifted and finished leaking out, but after a little bit it was all out also. This is just an idea for the tight wads like myself or the guys who maybe have multiple plugs in their tires and don't want to spend the money for new ones even though the stock Dunlops are a POS!
force61 is offline
post #2 of 13 Old 03-16-2010, 12:10 AM
700xxx's Avatar
I talked to a buddy at shawbs and he put a steel belted truck tire patch in mine.
700xxx is offline
post #3 of 13 Old 03-16-2010, 09:50 AM Thread Starter
force61's Avatar
How has it held up with all of the bending and flexing of the sidewall? I was just concerned a patch would end up peeling up so thats why I wanted to try and put a tube in it.
force61 is offline
post #4 of 13 Old 03-16-2010, 09:58 AM
I used plugs on a set of my fronts, they have done well so far, but the backs I would worry because of the rear tire spinning and pulling them out.
For peace of mind, I would get another tire or another full set. The reason I say that is that it's a pretty big deal when I finally get a chance to go out and ride and having to deal with that after all it took for me to get to where I'm going just to be sidelined by a tire issue.
I bring a full set of extra rims and tires with me for that same very reason. (just ask BDR455 - he can vouch) Now I realize everyone doesn't have an extra set lying around, but my point is how far I go to not have a sucky ride, and tire plugs failing would make it suck for sure.
post #5 of 13 Old 03-16-2010, 10:46 AM
420quadrider360's Avatar
stock wheel and tires are $hit
if your still riding stock wheels and rims, your riding a ticking time bomb!! 3rd ride sliced front tire, bent both rims.. first thing i upgraded!! i too when i ride take old tires and rims just in case..
prm 1 pc skid plate
prm edge "700xx logo" bumper
prm wayne matlock rear grab/toolbox
moose racing nerfs(rhino sprayed)
maxxis razr & maxxis razr2 tires
powered by THC
420quadrider360 is offline
post #6 of 13 Old 03-16-2010, 02:54 PM
I don't know if I would call it a ticking time bomb.
I've been on mine for a long, long time and only needed one plug because I wasn't running enough pressure in a rocky area. Oh and I bent a rear rim, but not horribly bad hitting a 6 inch rock "step" at high speeds. Didn't slit the tire or pinch the sides though.
I've been on mine in virtually every environment that you can imagine except sub-zero temps.
post #7 of 13 Old 03-16-2010, 03:15 PM
ive slashed 5 sidewalls now and have patched the inside and put tubes in them has worked great only about $15
post #8 of 13 Old 03-16-2010, 09:19 PM
I've been pretty fortunate and have never punctured a tire or bent a rim.... Odd enough though, I've bent 3 tie rods.
post #9 of 13 Old 03-16-2010, 09:36 PM
Maybe you should get a pair of these:
LMFAO!
post #10 of 13 Old 03-16-2010, 09:54 PM
I tried that, Reading glasses don't help much on the trails lol
