bearings and bushes - Club700XX - Honda TRX700XX Forum
post #1 of 2 Old 03-16-2010, 03:04 AM Thread Starter
bearings and bushes
hello guy a quick question have any of you had problems with worn bushes as there are no grease nipples on the trx700xx. or problems with front wheel bearings as there are no dust covers over the hub nut. just not sure if i should use a jet wash in thease areas.
cheers gary
mods to my trx700xx
corsasri is offline
post #2 of 2 Old 03-16-2010, 05:31 AM
I've never owned a honda that has had grease (zirk) fittings. And I use a pressure washer all the time to wash my stuff, and never had problems. Only bearings I've replaced were axle and swing arm bearings, but no prob thus far on the XX.
