ITP wheels - Club700XX - Honda TRX700XX Forum
post #1 of 19 Old 03-22-2010, 08:51 AM Thread Starter
Garrett22's Avatar
ITP wheels
would these work for my 700xx?
http://www.rockymountainatvmc.com/pr...#vehicleSelect
Garrett22 is offline
post #2 of 19 Old 03-22-2010, 05:16 PM
It all depends on the offset which should 3+2 and 4/144, they do say that it will fit our bike and RM are usually pretty accurate with their stuff.
post #3 of 19 Old 03-22-2010, 05:17 PM
Just read their info and they will fit our bike, price is not bad at all. Wish they would make one for the rear.
post #4 of 19 Old 03-22-2010, 05:28 PM
ScottR's Avatar
I just got ITP's and razor from Rocky Mountain. Fronts- 22" razor 2's and Rear-20" razor. love them both.
2008 trx700xx
2006 trx400ex
2006 trx300ex (recovered)
2007 trx250ex
2006 trx250ex
2008 tt125
ScottR is offline
post #5 of 19 Old 03-22-2010, 08:40 PM Thread Starter
Garrett22's Avatar
um. i was readin in a different post on here and it said somethin about the offset for the front and rear were the same offset. so would they fit the back too?
post #6 of 19 Old 03-22-2010, 09:09 PM
I know that the bolt pattern are the same but the front offset is 3+2 where the rear is 4+3, don't know much about calculation of the offsets but looking at the numbers, doubt that the front would fit in the rear but know for sure that the rear would fit in the front. If I'm not wrong; the 10" wheel for the rear has to be 5+2 to fit but hey! I might be wrong.
post #7 of 19 Old 03-22-2010, 09:24 PM
phucknutz's Avatar
Originally Posted by Garrett22 View Post
That wheel is only for the front end, it will not work on the rear
Big Kidz Racing
Sponsors:
EHS Racing
Barker's Performance
Houser Racing
On The Trail TV
West Virginia ATV Tours
Hinsen Clutch Components
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
phucknutz is offline
post #8 of 19 Old 03-22-2010, 09:32 PM
Stock wheel sizes and offsets for the 700XX are:
Front: 10x5.5, 4:1.5
Rear: 11x7, 5:2
Both are 4/144 bolt pattern.
The ITP rear 10" wheels are 10x7, 4:3 offset. The Douglas 11" wheels are the same as stock.
The first number of a offset is the inside measurement, the second is the outside. So if you install a ITP 4:3 wheel on the 700XX, the quad wil be about 2" wider overall compared to the stock wheels.
A front wheel will fit the rear, I have seen Wayne Matlocks 700XX's with front wheels on the rear a few times. (He does not ride them like this, he usually needs the rear tires on his spare quads for spares due to flats, just puts the fronts on so the quad can still be moved around.)
The front wheels you are looking at should fit just fine in the rear, but you only have a 5" wide rear wheel. I do not know if you could even find a rear tire that would fit on that narrow of a rim. Might be able to find a utility quad front tire in a 7" or 8" width, still not sure how that would work, fronts have a totally different tread pattern then a rear, not sure how they would work traction wise.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #9 of 19 Old 03-22-2010, 09:38 PM
phucknutz's Avatar
Rear: 11x7, 5:2
Doug
Yes they will fit on the rear but like you said I don't believe there is a tire that will fit it for the rear.
Big Kidz Racing
Sponsors:
EHS Racing
Houser Racing
On The Trail TV
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
post #10 of 19 Old 03-22-2010, 09:52 PM Thread Starter
Garrett22's Avatar
so does itp make this same wheel that would work for the rear using a rear tire instead of another front? i really like the way that these work and i don't wanna just by ones for the front.
