powerslide - Club700XX - Honda TRX700XX Forum
post #1 of 21 Old 03-30-2010, 09:50 PM Thread Starter
powerslide
i have razrs and it helps slide but what can make more of a slide ? swaybar?
tomtalbot10589 is offline
post #2 of 21 Old 03-30-2010, 10:42 PM
Lean more and push on the outside peg.
post #3 of 21 Old 03-31-2010, 12:58 AM
Now this may be a stupid question but lean to the inside and push down on the outside peg?
post #4 of 21 Old 03-31-2010, 06:40 AM
Tory trx's Avatar
You could try to tighten up your pre-load in the rear a little. The stiffer it is the better it will slide.
Tory trx is offline
post #5 of 21 Old 03-31-2010, 09:03 AM
Tightening the rear pre load will for sure help you slide better. The only thing I noticed with the tighter pre load is how hard the XX bounces when you go fast down a trail with deep ruts. The XX will jump up rather than just absorbing the pot hole and possibly bounce you off the machine. Almost happened to me a couple of weekends ago.
post #6 of 21 Old 03-31-2010, 10:18 AM
LOL, wow, I meant the inside peg, my bad.
post #7 of 21 Old 03-31-2010, 02:15 PM
Thats what I thought
post #8 of 21 Old 03-31-2010, 05:59 PM
You could always wait till it rains. This thing loves mud.
post #9 of 21 Old 03-31-2010, 06:33 PM
eclipsegs0's Avatar
another stupid ? how do u stiffen the preload.. turn the nut up or down?
eclipsegs0 is offline
post #10 of 21 Old 03-31-2010, 06:48 PM
More preload means you're tightening the spring. If you were looking at the shock from above you would be turning the nut clockwise or righty tighty. You're simply compressing the spring= more preload. How much do you weigh though? If you're a lighter guy like me you're going to barely tighten it.
