Stability with wheel size - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 06-14-2017, 11:11 PM Thread Starter
tomkat's Avatar
Hey everyone! Original member here, haven't been on in years!
I did some searching and can't find any posts about rim width and stability... So here goes.
I bashed in one of my original stock front rims (10x7) and did some reading to find that a lot of folks are running 10x5 3+2 or 10x6 3+3 on the fronts now. By the number of people running 10x5 in front and not reading anything about instability or brake and caliper exposure, it seems that it's no big deal. But I was wondering if someone here could comment and give me a more personal review if you have switched to 10x5 in front? Are the calipers and brakes too exposed? Taking any added damage since switching? Still running 21x7x10 tires? Is it tippy in corners with the narrower fronts? Does it track straight better or worse? Any impacts when jumping from going narrower? Is the 3+2 offset a problem or does it work?
Anyway, thanks for any feedback! Glad to see the site is alive and well!
Tommy
tomkat is offline
post #2 of 5 Old 06-15-2017, 01:15 PM
Quoted: 242 Post(s)
headscratch
Tommy
Your front rims weren't original if they were a 10x7" The oem front was 10x5.5". The tire size was 10x7x21" Rear OEM wheel 11x7". As far as I know w/out spending a ridiculous amount for a oem front rim, is why everyone goes 10x5 or 10x6, because Idt any after market company's make the 10x5.5 but I could be wrong. The 3+2 does expose a bit more of the front caliper, but I've experienced no damage. The plus side, is it helps widen the front out some. Which is nice when running the 10" rear wheels. If looking for new wheels I'd recommend DWT 0.190. And if you have some extra cash go to OMF and have them add the reinforcement rings.
post #3 of 5 Old 06-15-2017, 03:04 PM
Quoted: 141 Post(s)
Tommy
I put wider rims on the back of my XX
cataway is offline
post #4 of 5 Old 06-16-2017, 01:44 PM
blakjak619's Avatar
Quoted: 34 Post(s)
I thrashed a caliper down in baja and it ended up taking my entire hub and line with it
blakjak619 is offline
post #5 of 5 Old 06-16-2017, 02:48 PM
Quoted: 242 Post(s)
How did you manage that, was it from bending a wheel?
