Is this a good deal? - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 04-05-2010, 01:32 PM Thread Starter
08700xx's Avatar
I am looking to get some Elka shocks and i found this on ebay and just wanted to see if you guys think this is a good deal?
http://cgi.ebay.com/ebaymotors/Elka-...Q5fAccessories
08700xx is offline
post #2 of 11 Old 04-05-2010, 06:57 PM
You might want to check the for sale section on here. Someone was selling a setup like this for $1200.
shifterracer is offline
post #3 of 11 Old 04-06-2010, 12:27 PM
Yes and no. Yes, it's a good price... direct from Houser, this same setup is $2600.90. However, these are for FRONTS only and would not be set up for your weight... as in ordering them from Houser or Elka direct. I might add that these shocks may be too much shock for the average rider... lots of things that you probably don't need... such as the high and low speed compression adjustments. JMO
You might be better off with long travel a-arms and perhaps Stage 2+... save lots of money anyway.... $1570.00 for the Elite's compared with $940.00 for Stage 2+
post #4 of 11 Old 04-06-2010, 02:36 PM Thread Starter
08700xx's Avatar
Thanks. I will look into the Stage 2+. What is the best place to order them from? Thank you for your help.
08700xx is offline
post #5 of 11 Old 04-06-2010, 04:28 PM
wiigstyle!
talk with Josh at wiigstyle racing he is very friendly and helpful and will most likley beat their prices! they are one of our main sponsors so take care of them and they will take care of us.
post #6 of 11 Old 04-06-2010, 05:06 PM
Shovelhead's Avatar
Also, ATV GAlaxy will match prices too. I just haven't had no luck with them..Took us 1 1/2 months to get a CF Front hood for yfz450r..Kept getting excuses, but it finally showed up
Shovelhead is offline
post #7 of 11 Old 04-06-2010, 05:32 PM
Just to clarify, these will be set up to your weight, even states in the auction they will be built to your specs. When you order Elka shocks from a Elka dealer, they pass on the info directly to Elka, Elka then builds the shocks and they are sent to either you, or to the company you ordered from and then they ship to you. I have owned three sets of Elka's in the past, and even though I ordered them from a different Elka dealer each time, they still came from Elka. Unless you are buying used, a Elka shock should always come setup for you.
Yes, this is a good deal, but like Roadkill says, You may or may not need the extra adjustments. I also saw listings for the same setup with compression only and compression and rebound for cheaper. I have ordered a few things from ATV Galaxy and have never had a problem, good prices and has always shipped fast, but I do agree with Remingtonsteel, see what Wiigstyle can do for you, since he is a site sponsor.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #8 of 11 Old 04-06-2010, 06:08 PM
I doubt they'll honor eBay prices.
post #9 of 11 Old 04-06-2010, 06:19 PM
if your talking about wiigstyle their prices are already cheaper than the ebay prices.. i would deffinently give them a shot first if your going to be buying shocks.
post #10 of 11 Old 04-06-2010, 06:30 PM
The OP listed an eBay ad
