mud tires - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 04-05-2010, 05:31 PM Thread Starter
hmfman91's Avatar
mud tires
How many people are running mud tires on the rear? If I were to put 23x8x11 bear klaws on the rear would it mess anything up?
2008 RED/BLACK 700xx
hmfman91 is offline
post #2 of 5 Old 04-05-2010, 06:05 PM
it wont mess nothing up but youll loose a little hp because of bigger heavier tires, more rotating mass, learned that when i put heavier tires and rims on my 400 ex, but if you make up for it by doing some engine mods to compensate for it ,it wont.
post #3 of 5 Old 04-05-2010, 07:42 PM
I have the 24-10-11 kenda bear claws on the rear and I love it. If you swap the sprocket to a 13 or 12 tooth you will be great. I went with the 12 tooth and love it. You can creep over just about anything
post #4 of 5 Old 04-05-2010, 07:43 PM
I run these when things get to the good stuff (MUD).I would recommend the 13t front sprocket and stay awake. this setup + 22" Kenda Klaws XCF makes it handle real good.
post #5 of 5 Old 04-05-2010, 07:55 PM
kennyg700xx's Avatar
I run 24x10x11 mudlites on the rear with a 13t sprocket... LOVE IT!!!! Hasn't messed anything up yet, and i've put alot of long, hard miles on...
2008 honda700xx
2007 honda250ex(wifes)
2009 FORD F150 supercab
kennyg700xx is offline
