12 in wheels ?? - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 04-09-2010, 07:50 AM Thread Starter
glock17tj's Avatar
12 in wheels ??
I see everyone going to 10in wheeles, will 12in wheels fit too ?? I was looking for some that might fit the 700 that has the right back spacing. Does anyone know of any that will fit the 700xx ?? I guess they could be a little bit wider but not too much. It would really sling mud all over me then...
glock17tj is offline
post #2 of 4 Old 04-09-2010, 11:34 AM
I wonder though what your tire options would be. With the 10" wheel you have a shit ton of options. You might want to look into tire options first. If tires for the 12" rim are bigger than 24" tall you'll be miserable.
post #3 of 4 Old 04-09-2010, 12:03 PM
I would run 12" if they had a 22" or 23" tire similar to the razor, the only option they have of now are sand tires
post #4 of 4 Old 04-09-2010, 12:10 PM
yes they will me and whiskeydelta each had the itp 12in sandstar wheel kits but you will still be somewhat restricted on tire options.
