Shock Suggetion? - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 04-10-2010, 09:01 PM Thread Starter
kygoat's Avatar
Shock Suggetion?
Looking for smoother ride. No track, no racing and little jumping...
230 Lbs.
50% Fast Trail
50% Technical
Shock suggestions?
Thanks...
'05 Wolverine
kygoat is offline
post #2 of 4 Old 04-10-2010, 09:08 PM
230 Lbs.
50% Fast Trail
50% Technical
Shock suggestions?
Thanks...
Used DS450 shocks. $250-ish on ebay.
post #3 of 4 Old 04-11-2010, 03:54 AM
This is ok if you have power tools . If you have the money just buy a set of stage 1 Elkas.
post #4 of 4 Old 04-11-2010, 04:25 AM
markas214's Avatar
Better grips and handlebars. Stage1 Elka fronts and have Wiigstyle revalve, respring the rear. Around $900. Houser stem to reduce bump steer, $230 + clamp $85, Tiexera upper A-arm to tighten up steering. All this for under the price of 1 pair Elka Stage 4 or Fox Evol front shocks. This is what I'm thinking of doing. You could race this set up too. Oh I forgot a steering damper, $160-$500. I'm doing the CCP damper and shocks first and then will see how it rides before getting the other parts.
Renthal 13 tooth sprocket
Alba Pro Elite nerf bars
CCP steering damper
L8ton Racing 9/16 Swaybar
Teixeira upper a-arms
Powermadd handguards
markas214 is offline
