Elka shocks ?? - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 04-12-2010, 10:16 AM Thread Starter
glock17tj's Avatar
Elka shocks ??
set of elka front shocks fully adjustable with gibson a arm came off a 2005 honda trx for 300 bucks...So is this a good deal ??? and will it fit on the 700xx ?? If so I am going to get these....I may not be able to use the a arm But the shocks would be a deal ...What yall think ??
glock17tj is offline
post #2 of 7 Old 04-12-2010, 11:27 AM
They'll fit... just depends on the length of the shocks to be set up properly
post #3 of 7 Old 04-12-2010, 11:57 AM
wayne matlock's Avatar
No, they will not fit.
Wayne Matlock
matlockracing-honda.com
wayne matlock is offline
post #4 of 7 Old 04-12-2010, 12:46 PM
Even if they did fit, you'd probably need to get them re-valved and set up for the weight of your quad and you... different springs? Shocks that are set up for a lighter quad and rider will be way soft for something heavier. Add that cost to the shocks and see what the real cost is.
post #5 of 7 Old 04-12-2010, 02:15 PM
They should fit the front, shouldn't they????....
The Axis shocks I had before were from a 450R, and they fit... They just weren't set up right...
post #6 of 7 Old 04-12-2010, 04:36 PM
Depends on the a arms. Most 450r LT shocks are around 20" and standard length are 16.5". He would have to measure them.
post #7 of 7 Old 04-13-2010, 10:27 AM Thread Starter
glock17tj's Avatar
I saw them on Craigslist and was wondering if they would fit. For 300 buck I figured it might not be too bad of a deal. But if they are for a lighter rider I would have to get them revalved and set up for me. I am 6ft 220lbs...so I guess I would have to get them worked on..but if your a lighter rider they might work for you...I e-mailed the guy and will see what he says..thanks guys !!
