700xx drive shafts ? - Club700XX - Honda TRX700XX Forum
 1Likes
  • 1 Post By M_Quick
post #1 of 7 Old 07-21-2018, 02:06 PM Thread Starter
Talking 700xx drive shafts ?
High people, Im new on this site but not new to ATVs, grew up on farm, anyway I have a question about the Honda 700xx, I cant seem to find drive shafts anywhere for it, new ones or rebuilt ones, so Im wondering if the entire TRX range uses the same drive shafts, the hub has a 27mm bearing, inner hole, alot of the go cart shafts are a different diam at the wheel hub end, so do any of you guys know what I can use as a replacement or of a place where they can be purchased ?
I did dozens of searches, TRX 300 vs TRX 700xx shaft size, but no results showed.
piddlefoot is offline
post #2 of 7 Old 07-21-2018, 05:11 PM
Drive shaft? Mine is chain driven.
cataway likes this.
post #3 of 7 Old 07-22-2018, 01:06 AM Thread Starter
I bought the rear end of a Honda 700XX, it doesnt actually say TRX on it, is there a difference ?
I bought it for a go cart project, its the rear end, its a small go cart.
I dont understand how a chain system would work on an independent rear end unless you mean just to the diff.
I think the hub hole said 27mm, I need a shaft about 550mm long, to fit into that hub basically, so if anyone knows of any drive shafts that fit into the back of a Honda 700XX, please drop me a link ?
post #4 of 7 Old 07-22-2018, 05:11 AM
Quoted: 144 Post(s)
there is no Differential on the XX
cataway is offline
post #5 of 7 Old 07-22-2018, 06:00 AM
Footy's Avatar
Quoted: 47 Post(s)
See if you can post a photo of what you have. If it is for a TRX700 Rincon then there should be plenty of parts available for it. The 700XX was only produced for 2 years and that was 10 years ago so parts are become difficult to find.
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #6 of 7 Old 07-22-2018, 09:48 PM Thread Starter
WAS LINK HERE BUT FORUM WONT LET ME POST LINK WITH JUST 2 POSTS ?
First forum that's done that to me.
There was a pic of one there, so from my searches it seems they dont even make them new anymore ?
I dont actually need a 700XX shaft just a shaft that fits the hub bearing or even a totally different shaft and bearing as long as it fits into the hub itself , the bearing that is.
post #7 of 7 Old 07-22-2018, 09:49 PM Thread Starter
.atv.com/specs/honda/sport/2009/trx-tm/700xx.html]2009[/url] Honda TRX? 700XX Reviews, Prices, and Specs
Stick that in google bar and it should take you to same page with luck.
