Aftermarket ITP Wheel centering issue - Club700XX - Honda TRX700XX Forum
post #1 of 17 Old 01-09-2019, 09:04 AM Thread Starter
I purchased 10" ITP wheels to open up my tire options for the 700xx.
These wheels look great and pretty much match with my stock front wheels.
My new tires all around look great, but i have one lingering issue with the new back wheels mounting to the studs.
The holes in the rim for each stud are slightly larger than the stud itself, obviously. But when i get the wheel slid on, before putting the lug bolts on (flipped for the flat side since the new wheels are not tapered at the lug holes like stock), I can rock the wheels back and forth on the studs ever so slightly.
Without the lug taper, there is no real way to center the wheel on the lug perfectly. No matter how hard i try, i still get a slight wobble in my wheel every time i try to re-center it. I know that it is not the tire or the mounting of the tire on the rim. I've already tested that at a tire shop. I argued with them and they took me out in the shop and showed me the tire spinning on a mount. it looked perfect there.
So what are you guys doing to center the wheel? I have gotten it close on one side, but not perfect, and the other side i got lucky and seem to have it perfectly centered.
kyleking777 is offline
post #2 of 17 Old 01-09-2019, 10:16 AM
Footy's Avatar
Quoted: 43 Post(s)
So what you are seeing is a little bit of slop where the wheel meets the hub and lug bolts? I had the 10" ITP wheels and I do not remember that being an issue. The problem I had was bending the wheels upon impacts with rocks in WV.
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #3 of 17 Old 01-09-2019, 10:44 AM
/CUDA's Avatar
Quoted: 27 Post(s)
Hello,
are you putting the inner side of the wheels,
out, and vice versa?
Anyway, are wheels,
specific, with distance 144, right?
/CUDA is offline
post #4 of 17 Old 01-09-2019, 10:58 AM Thread Starter
Originally Posted by /CUDA View Post
Hello,
Anyway, are wheels,
If you mean, am i putting my wheels on inside out? like backwards? no i am not. im putting them on as they should be! yes the wheels are the correct pattern and spacing.
Correct, there is the slightest bit of slop in there, its very little, but enough that when i look down at my wheel when going down the road, my tread pattern does not spin around and around in a perfect line. I can see a slight wobble. I do not feel it, but can see it.
I just dont undertstand how to center them perfectly on the 4 lugs, as fast as these wheels spin, you would think this would be important!!!
post #5 of 17 Old 01-09-2019, 12:06 PM
/CUDA's Avatar
Quoted: 27 Post(s)
[QUOTE=kyleking777;243164]If you mean, am i putting my wheels on inside out? like backwards? no i am not. im putting them on as they should be! yes the wheels are the correct pattern and spacing.
Yes I meant that,
believing that the wheels had lug taper on one side.
So paradoxically,
you should enlarge the holes,
to allow nut, wheel
to enter, with the cone
and then center it,
but this is just theory,
surely you will receive more answers from many experts here.
/CUDA is offline
post #6 of 17 Old 01-09-2019, 01:47 PM Thread Starter
[quote=/CUDA;243166]
Yes I meant that,
So paradoxically,
to allow nut, wheel
and then center it,
Yes, I thought About doing this. But im concerned of messing them up. I mean, if hit a hole and ever slightly drill off center, i feel that could cause the wheel to become even worse.
post #7 of 17 Old 01-09-2019, 03:35 PM
Quoted: 253 Post(s)
The DWT wheels fit so tight, there hard to install. I think you are over thinking this. And there should be no way the wheel or tire moves once the lugs are torqued, unless you have bad wheel bearings. Do yourself a favor, and buy flange bolts for the lug nuts instead of reversing stock ones, or atleast add washers.
post #8 of 17 Old 01-09-2019, 03:40 PM
Quoted: 253 Post(s)
[quote=kyleking777;243168]
If you were to drill them, use a stepper bit. I had to open my one set of DWT's, after using the factory lug nuts reversed.
post #9 of 17 Old 01-10-2019, 09:49 AM Thread Starter
[quote=M_Quick;243174]
I think this is what im going to do, So that i can use my stock lug nuts and center it on the lug bolts.
I think if i do 2 on each wheel it should be enough to center them. diagonally from each other on each wheel.
post #10 of 17 Old 01-10-2019, 01:38 PM
Quoted: 253 Post(s)
If you're considering drilling these out enough to use two of the factory lug nuts with the tapered end towards the Hub, you may want to reconsider that. Your wheels do not have the reinforcement rings, like the OEM ones did.
Tags
center, tires, wheels
